Keyless entry
Keyless entry
Hey Gang,
I need some help installing a keyless entry system on my '05 Explorer Sport Trac. Before I dive into it I would like to know where the MASTER DOOR LOCK SWITCH is located. I'd rather not pull the door panel off if I don't have to, also is the switch a negative or positive trigger? Thanks for your help
DIRECTWIRE™ WIRING INFORMATION - FORD / EXPLORER SPORT TRAC / 2005 / Remote Start
12volts red (25A) + ignition harness
Starter red/lt. blue + ignition harness
Second Starter N/A
Ignition lt. green/purple + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory pink/black and brown + ignition harness
Second Accessory gray/yellow + ignition harness
Keysense yellow/green to black/pink - ignition harness
Power Lock pink/yellow - driver kick, door harness
Power Unlock pink/lt. green - driver kick, door harness
Notes: On vehicles with keyless entry, the CSM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1093.
Lock Motor pink/black 5wi driver kick, door harness
Unlock Motor red/orange 5wi driver kick, door harness
Parking Lights+ brown + headlight switch
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light black/pink + driver kick, harness to rear
Door Trigger yellow/black and gray/red - see notes
Notes: The driver door trigger is yellow/black in the driver kick, door harness. The three passenger door trigger is gray/red in the passenger kick, harness to rear. These wires must be diode isolated from the control module (instrument cluster) to avoid falsing. Refer to DirectFax document 1076 for wiring information.
Dome Supervision black/lt. blue + driver kick, harness to rear
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer tan/yellow ac PCM, pin 96
Notes: The PCM is on the passenger side firewall, under the hood.
Wait to start N/A
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - parking brake switch
Horn Trigger yellow/lt. green - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 556SW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes: Standard on all models.
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Trunk/Hatch Pin N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
SecuriLock
Part #: 556SW
Nash Bridges
60
05-12-2012 02:15 PM
SteelRollin
34
10-30-2006 02:25 PM
