Cold Start Problem - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Cold Start Problem
Old 06-12-1999, 12:55 AM
RadarRunner RadarRunner is offline
RadarRunner is starting off with a positive reputation.
Cold Start Problem
I have a 1988 Bronco with 302 fuel injected with 103,000 miles. It acts as if it is not getting fuel or enough spark to fire when first turn key. When I try the second, it seems to go ahead & start. It has only recently started this.
Thanks
Old 06-12-1999, 03:23 AM
79bronco 79bronco is offline
79bronco is starting off with a positive reputation.
Cold Start Problem
>It acts as if it is
>started this. Thanks
try a tune up. clean plugs and check timing.
Old 06-12-1999, 03:38 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
Cold Start Problem
when you do a tune-up replace the fuel filter
Old 06-25-1999, 12:11 PM
Bruce Bruce is offline
Bruce is starting off with a positive reputation.
Cold Start Problem
I had a '77 Ranchero that had a similar problem. I found that when cold I could crank and crank the engine and it wouldn't start. The funny thing is that after I let go of the key it would start. It was the wierdest thing and turned out to be the selenoid. When cold and the key was in the start position, the ignition wasn't getting electricity; but it would when the key was released and went to the run position. Fortunately, the engine was still moving and would get spark and start.
Wierd!!!
Bruce
Old 07-07-1999, 04:14 PM
Mulletwagon Mulletwagon is offline
Mulletwagon is starting off with a positive reputation.
Cold Start Problem
Old 10-19-2009, 10:14 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
Is this the first post ever on the Big Bronco section? or is there any older (and deleted now) one?
Anyway, i'll give it life once more... hehehe... just for you guys to check it out.
Old 10-20-2009, 12:48 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Someone has too much time on their hands.
Devil's playground, but I'll play along.
Hahahahahaha
running issues gibbsdakota Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-03-2012 09:05 PM
fuel system problems AFoster1025 Expedition & Navigator 6 10-25-2010 06:48 PM
engine turns but will not start.... mino54 1997 - 2003 F150 12 12-22-2008 01:08 AM
Fuel Control Module Smokeythebear 1997 - 2003 F150 0 03-10-2005 06:46 PM
fuel loss in fuel filter dieselpup 1999 - 2003 7.3L Power Stroke Diesel 2 01-05-2005 08:57 PM
Tags
1988, 1993, 302, 460, blem, bronco, cold, f150, ford, pro, problem, start, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
