1999 F-150 XLT 4X4 No Heat - Ford Truck Enthusiasts Forums
Old 06-11-2002, 08:48 PM
OhioRiverFordMan OhioRiverFordMan is offline
OhioRiverFordMan is starting off with a positive reputation.
Old 09-22-2002, 07:50 PM
jrsvj jrsvj is offline
jrsvj is starting off with a positive reputation.
No Heat when heat turned on. Engine running normal in Temperature Range What's up?
Old 09-27-2002, 10:10 AM
Deebo Deebo is offline
Deebo is starting off with a positive reputation.
[updated:LAST EDITED ON 27-Sep-02 AT 10:16 AM (EST)]Check your Gate valve out by the Fire wall. It's inline with one of the Heater hoses. Or the Dash control unit has something wrong.
It sounds like your gate valve is not opening to let the hot antifreeze in to the heater core.
Old 09-27-2002, 10:53 AM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
[updated:LAST EDITED ON 27-Sep-02 AT 10:54 AM (EST)]Verify that the coolant level is ok as well. The temp guage may not signal an insufficient quantity of coolant in cooler weather. I would also consider a cooling system flush in the future if a stuck valve is the cause.
Old 01-28-2003, 08:24 PM
RCollins291 RCollins291 is offline
RCollins291 is starting off with a positive reputation.
This same problem just started with my 1999 F-150 today. I just found this website today search for answers to this problem. Good info. Thanks guys helped me a lot.
Old 02-02-2003, 08:23 PM
bosshoss bosshoss is offline
bosshoss is starting off with a positive reputation.
I had a truck that had a bad temp control ****. I pulled the temp control **** off and turned it with plyers, ah heat. Replaced **** problem solved. The old **** had a small crack that would let the **** slip on the shaft and not turn on the heat.
Old 02-06-2003, 07:29 PM
AegisSailor's Avatar
AegisSailor AegisSailor is offline
AegisSailor is starting off with a positive reputation.
Being from Ohio myself, I've experianced this problem before as well. Cut a piece of cardboard big enough to cover most of the radiator. Then shove it down in front of the radiator to block the wind from hitting the radiator. Works like a champ. Of course, you only want to do this if it is real cold out.
Old 12-21-2003, 12:32 PM
vaders vaders is offline
vaders is starting off with a positive reputation.
No Heat? Check this first...
The newer f150s don't have a valve in the heater hose to control the heat. Heat is controlled by an air damper in the heater box. The damper is controlled by a small servo motor unit on the bottom of the box and the position of the servo is controlled by the variable resistor connected to the temperature control **** on the dash. If you don't have heat, check the servo motor first. It's easy to get to and easy to replace.
4x4 issue Welder7018 Expedition & Navigator 24 08-09-2015 10:06 PM
2001 e350 4x4 ryan peterson 1968-2013 Full Size Vans 4 07-13-2015 02:51 PM
supercab 4x4? Schickel 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-13-2014 10:25 PM
Offroad & 4x4 351slug Offroad & 4x4 7 03-16-2013 11:11 PM
best year explorer 4x4? unknownauthor Explorer, Sport Trac, Mountaineer & Aviator 3 02-24-2003 02:12 PM
Tags
150, 1999, f150, ford, heat, problem, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
