top dead center and balancer timing marks - Ford Truck Enthusiasts Forums
Old 05-26-2007, 09:40 PM
71dusterdan's Avatar
71dusterdan 71dusterdan is offline
71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.71dusterdan has a spectacular reputation.
Talking top dead center and balancer timing marks
okay my carb swap is done my dumbed down 89 is running and not to badly, it still needs to be timed. i can not see any timing marks on the factory balancer, just a line cast across the edge of it, but it doesnt line up anywhere close to the pointer with #1 at tdc. here are the facts. 89 351w, according to the books #1 is the left front when looking at it from the grille. i dont know if the balancer is factory but have no reason to make me think otherwise. how about some help. my dui distributor needs to be timed at 12 degrees before. it runs pretty good so i must be in the ballpark. I bought a timing tape and as soon as one of you guys can tell me the foolproof way of finding tdc and the same on my balancer i am in business. thanks, Dan
Old 05-27-2007, 04:23 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
#1 is the front passenger side. There is only 1 line across the balancer for TDC. Remove the number 1 plug, unhook the 12V to the dizzy, bump the engine over until your finger is blown off of the plug hole. There is a weak blow when it is on the echaust stroke and a stronger one on compression stroke. Then you are real close to TDC. The line should be near the pointer at this time. then you can line it up @tdc. If not, then the outer ring may have slipped on the balancer and needs to be replaced.
Old 05-27-2007, 07:27 AM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Also helps to use a drill and wire wheel to clean the balancer face, then you'll see the timing marks. I paint em afterward. Paint the area, then wipe off the excess, the paint left will be down inside the grooves.
Old 05-29-2007, 09:38 AM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
And make sure the balancer is absolutely clean before you install that timing tape, or it won't be there the next time you look. (And they don't seem to hold up well to continuous 7200 RPM blasts...but I don't imagine that'll be a problem for you...)
Old 06-01-2007, 11:03 AM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
On my balancer there is a deep groove that on chevys are normally the tdc mark. 180 degrees from that groove on my 28oz ford oem balancer there are the actual timing marks, although hard to see, with marks every one degree from 10deg ATC down to 0 and then one for degree up to 10deg BTC. Why are there two marks on this balancer?
Old 06-02-2007, 07:16 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
I have found that holding a long piece of thick copper wire down into the spark plug hole of No. 1 cylinder allows me to feel the piston traveling up or down quite well. Hold this in one hand and in the other hand hold a breaker bar (not ratchet) with appropriate socket on the crankshaft balancer bolt. Now as you rock the crankshaft back and forth you will feel the piston going up and down and can very accurately find TDC.
harmonic balancer & TDC off abyars111 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 10-04-2014 07:57 PM
5.0 Harmonic Balancer Marks Hypoid Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 06-28-2014 01:48 PM
1986 4.9L timing marks on Balancer help 1967 Tempest 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-27-2014 05:09 PM
302 timing mark on harmonic balancer CJ7 1987 - 1996 F150 & Larger F-Series Trucks 3 11-25-2003 06:42 PM
Ignition Timing Mark on Balancer stevieweevie 1987 - 1996 F150 & Larger F-Series Trucks 13 10-21-2003 06:30 PM
Tags
1992, 302, 69, acurately, adjustment, center, dead, f150, find, ford, liter, marks, mustang, setting, tdc, timing, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
