Ford 6 inch question.
I recently was given a 9 inch rear end with 3.50 gears that I am planning on installing in my 49 half ton. It was partially disassembled when I got it. The third member and axles were out of it. I’m not sure what it came out of but it has 28 spline axles with the big bearings. My question is where do the axle seals go? It doesn’t appear to have any on it. Does anyone have any pictures showing the axle seals? Also, should I use a gasket when installing the third member? The guy at the local parts house said not to. He said to just use RTV. Any help would be greatly appreciated!
Rick
Rick
Originally Posted by MN 49
I recently was given a 9 inch rear end with 3.50 gears that I am planning on installing in my 49 half ton. It was partially disassembled when I got it. The third member and axles were out of it. I’m not sure what it came out of but it has 28 spline axles with the big bearings. My question is where do the axle seals go? It doesn’t appear to have any on it. Does anyone have any pictures showing the axle seals? Also, should I use a gasket when installing the third member? YES - E3TZ-4036-B The guy at the local parts house said not to. He said to just use RTV. Any help would be greatly appreciated!
Rick
Rick
Before doing too much, you better verify that 9 incher will work in a 1949...if it's a 9 incher made after 1972, it'll be too wide.
I agree with the guys on making sure that rearend housing will fit in the 49. If it does, your axle seals are installed in the ends of the housing. The bearing on the axle actually butts up to the seal. You should see a seal if you look in the end. The seals are pressed in similar to the timing housing seal for the harmonic balancer. Seals are cheap and theres a little tool you can use to pound it in. As for the 3rd member, I have never used a gasket and only use the Ultra black gasket sealer. In fact, my buddy has a rearend shop and he doesn't use a gasket either. The silicon will seal it. I also use silicone on the bearing plates that bolt up to the brake housing. Let's see, I've removed my 3.0's, put 3.5's in, then took them out and put 2.75's in all within a 2months period. I have no leaks at all. Good luck with the rear end.
on
If there is two ways to install them I’m sure I would have put them in backwards.
Here's a little bit of reading on 9" Ford Diffs;
http://www.kevinstang.com/Ninecase.htm
Bobby
