Bad Fuel Injector Symptoms - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-25-2007, 10:41 PM
JeremyH JeremyH is offline
JeremyH is gaining momentum as a positive member of FTE.JeremyH is gaining momentum as a positive member of FTE.
My dad has a 2000 F250 7.3L and he is thinking that he might be having trouble with his injectors. What are symptoms of bad injectors?
Can diesel injectors be pulled and cleaned just like gas engine injectors (pull and spray with carb cleaner)?
Thanks,
Jeremy
Old 05-26-2007, 02:54 PM
Bump.
Anyone?
Old 05-26-2007, 03:30 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
You might take this to the dedicated 99-03 7.3L Diesel section, but injectors can be a failure point. I'd take a good look at the high pressure oil system, fuel pressure, fuel pickup in the tank, and make sure the filter is good before I'd suspect multiple injector failures. If you have access to someone with AE (AutoEnginuity), it can tell you volumes about what's going on...
EDIT: Forgot to mention -- when injectors fail, you can get oil in the fuel filter, so look for that, too.
Joe
Old 05-26-2007, 03:34 PM
Uzumati's Avatar
Uzumati Uzumati is offline
Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.
What symptoms is he having? Rough running?
Old 05-26-2007, 03:42 PM
Izzy351's Avatar
Alan's here -- you're in good hands...
Old 05-26-2007, 04:52 PM
enominus enominus is offline
enominus is starting off with a positive reputation.
with me on my 6.0 it was running very rough, sounded like my engine was about to jump out of the hood. and i had an extremely harsh vibration at a certain rpm, like a wheel was about to come off.
Old 05-26-2007, 05:57 PM
Rough idle with a slight vibration at the rear of the truck.
Also, upon deceleration, it hesitates slightly.
Old 05-26-2007, 07:23 PM
Uzumati's Avatar
That does sound injector'ish but before committing to replacing one or more Ohm out the Under Valve Cover Harnesses. The 01's and earlier had an inferior connector on the inside and it can come loose.
Old 05-26-2007, 07:48 PM
OK. I'll let him know to check it.
For personal knowledge, can these injectors be easily pulled and cleaned? I have pulled and cleaned many injectors on gas engines, but those are a bit different due to the lower fuel pressure.
Old 05-27-2007, 04:27 AM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
Moved to 7.3L section.
Old 05-27-2007, 07:50 AM
Uzumati's Avatar
Not as easy to pull or clean. The HEUI system uses high pressure motor oil (~3000psi) ti drive the injector. Here is a little education on the injectors. http://www.intellidog.com/dieselmann/injector.htm
To check the harness ohm it at the Valve cover connector on the outside.
Pin Out
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
***The injectors fire with a 115VDC signal from the IDM do not pierce to wires to test.***
Ohm between "I" and "C" to test the injectors, should be less than 5.0 Ohms
To check glow plugs Ohm between "G" and battery ground should be between 0.1 and 2.0 Ohms
Old 05-27-2007, 10:30 AM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
As previously mentioned, the best thing to do is check it for codes and do a contribution and Buzz test, especially if the harness ohms out OK.
John311t John311t is offline
John311t has a good reputation on FTE.John311t has a good reputation on FTE.
WHen the TC locks up into 4th gear, does the truck shake when giving it a little fuel, then if you mash the foot to the floor is kinda goes away and if you let up does it go away?
Old 05-28-2007, 12:17 AM
John,
not sure. He hasnt tried that...
Alan, thanks for all of the info! I passed it along to him....
Old 02-11-2010, 06:06 PM
black smoke 350 black smoke 350 is offline
black smoke 350 is starting off with a positive reputation.
this is what my 04 6.0 does what the hell is it bad injectors
Injector harness resistance check tnwill 1999 - 2003 7.3L Power Stroke Diesel 4 07-27-2016 09:12 AM
Upgraded injectors dont need tuning.. Anyone else hear this??? ol-blu 6.0L Power Stroke Diesel 10 03-03-2013 08:06 PM
FICM is it bad or am I being played? 6litrefan 6.0L Power Stroke Diesel 11 01-28-2012 01:11 PM
Symptoms of bad or worn injector o rings reyjav 1999 - 2003 7.3L Power Stroke Diesel 5 02-03-2011 06:44 PM
Bad Injector Symptoms??? ShayneO Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 01-04-2011 06:57 PM
Tags
60, 73l, bad, deisel, diesel, failure, filter, ford, fuel, injector, injectors, ohm, symptoms, test, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
