WHen the TC locks up into 4th gear, does the truck shake when giving it a little fuel, then if you mash the foot to the floor is kinda goes away and if you let up does it go away?
My 07 6.0L, 160800kms is doing that to me. does that mean bad injectors? I put some diesel kleens in the tank and was hoping that would clean the system a bit but either than that I was blaming bad fuel.
I have a 1996 ford f25 with the 7.3 turbo it runs an idles fine but when you put it in drive or reverse it has no power its like it's booged down . I push the pedel to the foor still no power . What's wrong ????
Welcome to FTE, I know the motor is very similar, my guess would be fuel restrictions or bad injectors/ICP or IPR there are alot of variables we would need more info, but I think you will have better luck in this forum
these are my exact symptoms, I know its an old thread, but I need help. I also get cel at 1500rpm
Those are my exact symptoms. I get a cel light 1500 rpm when I let off throttle, cel goes off at 900rpm then truck will generally drive ok when i depress the throttle. Only seems to happen when truck is warm. Ive replaced lpop, hpop, icp, ipr, left and right uvch pigtails, left and right uvc gaskets, right fuel line, fuel filter, idm, bellowed up pipes, turbo pedestal seals, new collector to turbo clamp, new brake actuater sensor, 6637 air cleaner, ebpv sensor, iat sensor, map sensor. All parts are either motorcraft or alliant.
