I just got one key with my "new to me" 2001 superduty. I had one cut at the hardware store the other day but I haven't used it because the person who made the key thought the factory Ford key might have the anti-theft chip in it. Does it?
Not all of the trucks have the PATS. In 01 I thought it was limited to the Ex's
If you do you will have the following:
THEFT indicator located in the instrument cluster (inside the tach below the "3")
encoded ignition key
transceiver module surrounding the ignition key lock cylinder
PATS control module located under the instrument panel on the center support
Just try the Key. If its the big key, which it shouldn't be, but if it is. It won't work. It will only open the door.This is the Pats key that Amiller described. The Pats key has a very small access looking panel on the bottom of the key. If it's the smaller design key, it will work. Did yah get 2 key Fabs too? If you didn't let me know. I'll send yah one. I think the dealership gets about $30.00 for these... Take Care.Country
Thanks;Sorry if its a little crude guys. I'm still Learning how do this thing. I actually put some pic's of my rig on web shots too HAH.. .Take Care..Country
WOW! Thanks for all the replies. I've got the small key (non-PATS). I picked up another remote transmitter off of ebay for $19 and got it programmed, so it looks like I'm all set.
