i am a 14 and need someone to help me with my ford f-150
i have a 2000 f-150 v6 and i want a exhaust system like a flowmaster and i have been told that my truck dont have enough power for dual flows to sound good on my truck is this true?u can instant message me at cody01king on aim or email me at aboyinabox@hotmail.com thnk you for help
If you leave the stock cats in place, you can run dual flowmasters and it will be fine.
It will sound ok.
__________________
Phil
DE Chapter Board Member/New Castle County 2003 SuperCrew
DSS Built Lightning block/Stage 3 heads and cams
L-conversion/Kenne Bell upgrade blower at 18 PSI
BTS/4R100 tranny
100 shot nitrous
1.68 60' time/11.76 @ 116.17 TRUE GRIT!
2000 Grand Marquis JOIN THE DELAWARE CHAPTER,CLICK HERE
One of my good friends has a '99 F-150 with the 4.2L, doesn't sound too shabby with a Flowmaster 40. It's not a V8 by any means...but it sounds pretty good for a six (Flowmaster sounds much better on the 4.2L than my 4.0L IMO).
Does the Flowmaster you are talking about just replace the existing muffler? Like they chop out the old one and weld in a new one? How much does it cost to have this done, or can I do it myself? (The existing muffler seems kinda big.)
I have a flowmaster catalog here. Which model did your friend have. There are several 40 series models. Can you describe the sound?
Xyzzy, multiple styles are available. There are drop in replacements, where you just remove the old muffler and weld in a replacement. You can do this yourself if you have skills with a welder, though you may need some pipe as well. There are also cat back systems, which replace everything after the catalytic converter(s). These also, can be installed by you, if you know how to use a welder or just use clamps.
He has the 40 series delta. It's got a good rumble too it, deep and sounds like basically every Flowmaster vehicle known to mankind lol. If you drop me a PM or an email from here I can send you a couple of sound clips of it.
rangerpilot well this weekend i am going to a muffler shop and going to have a 22" thrush glasspack put on my truck and i will post some sound clips ad stuff........thank you for your help and if you think this is not a good idea post soon it will be done this weekend!!!!
