First 6.4 tuner is out...
Bullydog is supposed to be out soon also. (Rumored to be first of June also)
http://www.bullydog.com/Diesel_Power_Pup_07_08.php
http://www.northtexaspowerstrokes.co....php?pos=-8146
http://www.northtexaspowerstrokes.co....php?pos=-8147
Originally Posted by jlh_1
does anyone know about the foot print left on the computer???
Thank you
Jason
Thank you
Jason
Back to the same old adage "If your going to play, then you gotta pay"
Originally Posted by ag-ford-4x4
So whats the o/u on the "i put a chip in, now i need warranty work" threads?
on
Originally Posted by SuperchipsMike
"the 2008 trucks records and stores everything"
Where did you get this information from and how are you verifying it?
Here is a discussion at least:
https://www.ford-trucks.com/forums/5...ghlight=vloney
#28
This is a quote from the 2008 owners manual "Some vehicles are equipped with Powertrain Control Systems that can detect and store information about vehicle modifications that increase horsepower and torque output; this information cannot be erased and will stay in the system’s memory even if the modification is removed. When a dealer or repair facility works on your vehicle, it may be necessary for them to access the information in the Powertrain Control System. This information will likely identify if any unauthorized modifications have been made to the system and may be
used to determine if repairs will be covered by warranty."
It also explains the event data recorder ( accident recorder or black box) and service record recorder.
On my '08 there is also a sticker under the hood warning about modifications, I don't see why Ford should not be able to void your warranty if they feel the modifications caused a failure. One example is a transmission failure, it could be due to a mod increasing the engine torque above the Ford specifications. The posibility of the mod causing the failure could void your warranty.
#29
#30
Ok maybe this will help a little bit. I have a Bully Dog Triple Dog programmer, and I called bully dog today to ask when the new program for the 2008 would be out, since I have one on order that is supposed to be here next week. I got lucky enough to talk to one of there lead tech support guys. I asked him about this rumor that if you program the 2008's, that Ford can tell. He told me that it was completly false, that the only programmer he knew of that left any type of footprint was the superchip, and even still, it wasn't a footprint that was detectable as an aftermarket tuner. So according to bully dog's stance, there product will not leave any kind of "footprint" behind. He also told me that they had the problem with the exhaust throwing flames, they took it in for the recall fix and ford didn't detect that the computer had even been messed with. Just thought I'd pass the info along.
