Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-25-2007, 09:45 AM
jpetit is starting off with a positive reputation.
Vacum Port
Can any one tell me what port to use when vacuuming a 2000 f150 AC commpressor before loading the freon High pressure or low pressure port wich one Please.
Thanks in Advance
jpetit
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-25-2007, 10:20 AM
lsrx101 is gaining momentum as a positive member of FTE.
Quote:
Thanks in Advance
jpetit
The vacuum pump needs to be connected to the center port (yellow hose) of a manifold gauge set and both valves opened for evacuation. Evacuating and charging by swapping hoses around will allow air into the system that will cause cooling issues. This is especially important if you are using a "venturi" type vacum pump (air operated) as they leave residual air in the system to begin with.
Evacuation is done through both ports, Charging is done through the low side only.
Harbor Freight has a gauge set for about $35 that is good for DIY work, or you can often rent a manifold gauge set from a local chain parts store (Auto Zone, Advance, etc.)
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #3 (permalink)
Old 05-25-2007, 12:12 PM
Thank you Brother, I leave in south Fl and there is one of those abor freight Stoer by my job I"m going to get me a gauge set tis weekend.
jpetit
  #4 (permalink)
Old 05-25-2007, 10:08 PM
jpetit
Harbor Freight carries a good bit of junk, but there are a lot of jewels there if you know what to look for. They have an AC flush gun kit for about $25 that works really good for DIY.
I see you're in South Fla. You need to give your AC all of the help you can down there. I'd recommend a new accumulator for about $30, it makes a big difference. You would also be amazed at the difference a new fan clutch would make at idle and low speed. Think about it.
__________________
  #5 (permalink)
Old 05-26-2007, 11:30 AM
Thanks guys for all the helps
jpetit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
