Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-25-2007, 07:11 AM
MikeSDK's Avatar
MikeSDK MikeSDK is offline
Garage is empty, add now
MikeSDK is starting off with a positive reputation.
What steps to change to B20?
Hello folks-
I have been running diesel with Power Service fuel additive in my 7.3, but I am very interested in switching over to B20. I have recently found a few stations in my area that are supposed to be carrying it, so at least locally, I should be able to find it.
I have a few questions however-
If you are travelling, what do you do if you can't find a biodiesel pump? Is it OK to go back and forth with regular diesel?
Are there any steps I need to take to prepare my truck to run Bio?
Do I need to use Lucas or some other product as a 'top lube' additive?
Are there any threads here in this forum that can help clarify some basics for a beginner and give me some directio on getting started?
All help is appreciated!
__________________
Mike
2002 F-350 Lariat CC DRW 4x4 7.3L PSD
Isspro EV A-pillar, AIS intake w/ fender sleeve, 5' exhaust, KCM HPX, Tru-Cool Max, BTS VB, RDP FRX, AIH delete, plenum inserts and boots, and Casserly Stage 1 Injectors, 38R and DP Tuner (live tuned) thanks to the gang at RRE 2012!
  #2 (permalink)
Old 05-25-2007, 08:45 AM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
The only suggestion is to carry an extra fuel filter as bio will clean out your system and shove all the junk into your filter. Swithing back and forth will not affect your engine whatsoever. Youll want your addatives for the low sulfer diesel but b20 overcomes all of the lubricity factors. No addatives for b20, addatives for number 2.
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #3 (permalink)
Old 05-25-2007, 10:22 AM
Murphy2000 Murphy2000 is offline
Murphy2000 is starting off with a positive reputation.
Just dump it in and go..
The fuel filter clogging thing is half myth and half truth...
I tell folks to carry the extra filter just in case but after thousands of gallons served, I have not had one report of a filter actually clogging..
That's not to say it doesnt happen, but its rare..
  #4 (permalink)
Old 05-25-2007, 11:24 AM
Wheatina's Avatar
Wheatina Wheatina is offline
Wheatina is starting off with a positive reputation.
Mike...you don't need to change a thing, or do anything to prepare for using B20, or any biodiesel mix (using straight unprocessed vegetable oil is different...that's where you have to make some changes). Your PSD is all ready to go. Fuel lines and associated gaskets and seals are all made of materials compatible with biodiesel in the newer models from around 1996 on.
No additives needed!!
When you can't get BD on the road, you can go right back to petro diesel with no problems...that is if YOU can stand it after running BD. The truck can take it, but I can't!! You'll probably find that the truck likes BD better, too, I'll be installing an extra tank in the bed when I start traveling beyond BD suppliers.
Don't hesitate to try some BD!! You, and your truck, will love it!
__________________
'99.5 PSD 7.3L 4X4 manual 6-speed F350 Lariat Dually Ext. cab long bed(Big Red)
http://www.3dflags.com/media/icon/cl...s_wa_2fawm.gifhttp://www.eapglass.com/FlowerPowerSm.jpg
  #5 (permalink)
Old 05-25-2007, 11:45 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
As previously said "no modifications to B20" but if your fuel system is rusty/corroded. It will find a pinhole and start to leak easier than on #2. It will clean your fuel system squeeky clean and any rust , gunk from over the years will find its way to the fuel filter.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #6 (permalink)
Old 06-04-2007, 10:17 AM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
You won't have as many problems with B20 in a 2002, but in my 88 I went thru so many filters when I first started It almost made it not worth it, but then it just stopped, not more problems, but in a newer truck there is not as much corrosion in the first place.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #7 (permalink)
Old 06-12-2007, 08:25 PM
vettehauler's Avatar
vettehauler vettehauler is offline
vettehauler is starting off with a positive reputation.
You have a much greater chance of loosing a seal from running straight ULSD than you will ever have running Bio-Diesel, Ive run it now for over 3 years, and trust me I am a firm believer. My truck runs quieter and smoother.
one note though; I was running B35 this winter and for the first time ever it did gel up on me. But that was my own stupidity for not adding any additives.
__________________
Regards
Drew
2002 F250 4x4,Lariat,PSD,6 speed, Island Blue, SCMT-Autometer Boost and Pyro, 4" downpipe, 5 " exhaust, "Cat" removed....thats all for now
  #8 (permalink)
Old 06-19-2007, 07:50 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I started running B20 in my 02 at 155,000 miles. I checked the filter every week because I was scared of it plugging up, but never noticed it getting dirtier than normal. Like others said switching back to #2 is no problem just have some additive handy if you're going to burn several tanks of it to help with lubricity.
  #9 (permalink)
Old 06-19-2007, 09:16 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is online now
Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.
I've been running B99 at least 3 out of 4 tanks for the last six months without issue.
__________________
Andy
2012 Race Red Boss 302 "Commuter Car"
Early 99 F250 PSD 4x4 CC 6spd Common Mods 260,000+ Miles, Driven daily like a rented mule
1964 Falcon Convert 289 Toploader 9" 4 Wheel Disks
Nov '10 Recipient: "dedicated report-back tech thread poster" award!
  #10 (permalink)
Old 06-20-2007, 12:10 PM
mongo75's Avatar
mongo75 mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
danny jones
Fat- I've never understood "B99"- why bother putting just 1 gal of #2 into 100 gallons of bio??
__________________
Danny PAA member #12
SoCal Chapter Member
E99 F-350 Dually Van turbo 4x4 CC LB 7.3L, AFE intake, 3 gauge pillar, 4" Magnaflow SS str8-pipe, DP Tuner, Swamps 175/146 SS inj, ARP head and bottom studs, Comp 910 springs, ITP Ovrbst, CCV mod, SS HPX, home made Reg-return, Foil Del, ZooDad, Air Horns 320hp/704tq
  #11 (permalink)
Old 06-20-2007, 01:11 PM
Fat Diesel's Avatar
I'm not sure either. It just comes out of the pump that way...
Oh yeah. I went to school with Brian Burke, just thought you might know them.
__________________
Andy
  #12 (permalink)
Old 06-20-2007, 01:21 PM
howardq99 howardq99 is offline
howardq99 is starting off with a positive reputation.
Quote:
I believe that with B99 it qualifies for a 99 cents per gallon rebate. At least that is what shows on my receipt here in Phoenix. The line reads "99% AGRI-BIODSL PRICE INCENTIVE" then lists the number of gallons at a price of -0.99 per gallon and then subtracts that from the total cost.
__________________
2004 EB Excursion 4X4 6.0L PSD 3.73LS /3" Donahoe Racing Lift & Shocks / Landyot Radius Rods /ARP Head Studs / Blue FPR Spring / Hellwig Anti-Sway Bar / Firestone Airbags / Dieselsite Coolant Filter / Stealth Automotive CCV Filter Kit / Harpooned / HFCM Plug / Silverstar 9005s in the fogs / Fumoto Valve / SyncroMax in Transfer Case / Magnafine PS Filter/ ART Rotors & Hawk Pads / LT275/70R18 Hankook DynaPro ATm RF10's on Helo MAXX Rims / 2006 ATC Custom Trailer w/Hensley Arrow Hitch
  #13 (permalink)
Old 06-20-2007, 08:25 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Blenders of Biodiesel receive a $1 per gallon rebate from the Feds for every gallon used, But DO NOT get the rebate for B-100. Some blenders pass the savings on to customers, but a lot do not...............
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #14 (permalink)
Old 06-20-2007, 09:58 PM
mongo75's Avatar
danny jones
Gotcha- it don't matter to me as I have yet to find a commercial bio station here in so cal
__________________
  #15 (permalink)
Old 06-21-2007, 07:00 PM
Here is a list in Cal. I see a few in S. Cal. Hopefully near you. http://www.biodiesel.org/buyingbiodi...tate.asp?st=CA
__________________
B5 soydiesel user
Sirius radio
Tags
73, b20, build, change, f350, ford, running, steps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
