yet another toy ps box Q.
Just talked to a friend who's dad has an '87 toy. 4x4 parts truck. I understand I need a 79-84 box for my F1. Now are the newer boxes the same size or shape? I just hope to use it for finding the proper spot to set my engine, until I find the right box. But, I suppose the 87 couldn't work, by chance, could it? I haven't visually seen it yet.
The later boxes were these long skinny things, if it's a small compact box you're go to go.
There is a picture of the right box in the tech article here:
https://www.ford-trucks.com/article/...60_Trucks.html
yup, thanks.
In looking at walston's pic (thanks Mr. Walston) of the MF bracket,
I assume the bottom flat rests on the lower frame flange, which would line up the bolt holes to be drilled on an F1 frame? Also, does anyone have a measurement offhand to how much wider the Toy. box is? (inboard)
Maybe I can just find a matching piece of angle iron to lay over the stock box to set my dimensions for engine placement.
OK, the bottom flat (lazy V) sits even then, thanks again.
the bracket sits like a "lazy" V in the frame on the small flat at the point of the V. The rear leg of the V is parallel to the column and is the part the box mounts on. The mount when used on the 53-56 matches up with the 3 holes for the stock box. I'll try to remember to measure my box and get a picture of the box and mount. I currently have the fender off on that side.
I just got done looking at Bobby's gallery. He uses the same size flatbar I have at work. I noticed it's mounted up front, too. I'll check out 1949f1's next. And I just got an email from a fella (sellin me an 88 turbo coupe) who happens to have a flathead 8ba for sale, too. What an exciting, yet confusing, 15 minutes this was.
