Propane gas cylinders must be transported so the relief valve communicates with the vapor space inside of the tank. For that reason, you should never transport a cylinder lying on its side unless it's a cylinder designed for horizontal use. The pressure relief valve could becomes liquid full and the valve could fail to open, the container could rupture.
