95 F150 wiper motor removal
Old 05-22-2007, 09:56 PM
easygo's Avatar
easygo
easygo is offline
Question 95 F150 wiper motor removal
Wiper motor on 95 F150 slowed then quit, have 93 E150 same 300 in line 6.are wiper motors interchangable.would anybody have diagrams or instructions on removal. Giving truck to son for 1st auto trying to fix few items.Any help appreciated.
Thanks
Ian
Old 05-23-2007, 07:12 AM
PhilcoPGM's Avatar
PhilcoPGM
PhilcoPGM is offline
F150 wiper motor replacement
I have a 93 F150 and the wiper motor doesn't work at all on any speeds. Can anyone give instructions on how to replace? Thanks in advance.
Old 05-23-2007, 07:54 AM
Conanski's Avatar
Conanski
Conanski is offline
You have to unbolt the trim piece behind the hood at the base of the windshield. The linkage and motor are under it.
Old 05-23-2007, 08:14 AM
lostin90s's Avatar
lostin90s
lostin90s is offline
you may have to loosen hood to get cowl panel off to work on motor linkage. If you have problem get at arm bolt. Then like Conanski said . Good luck
Old 05-23-2007, 12:13 PM
Wingman69's Avatar
Wingman69
Wingman69 is offline
I changed my wiper motor on my 93 F150 a couple of weeks ago. It's somewhat easy to do, the hardest part was getting the linkage unhooked. Here are the general steps.
  1. Disconnect battery ground cable.
  2. Remove both wiper arm and blade assemblies.
  3. Remove cowl grille attaching screws and raise the grille slightly.
  4. Disconnect washer nozzle hose, then remove cowl grille assembly.
  5. Remove wiper linkage clip from motor output arm.
  6. Disconnect wiper motor electrical connector.
  7. Remove wiper motor attaching screws and the wiper motor.
  8. Reverse procedure to install.
It is a little tough getting the cowl grille out with the hood on, but just go slowly.(It might go easier with 2 people on that step.) Try not to beat or drop the new motor, there are ceramic parts in it that could break. A more detailed instruction can be found @ http://www.autozone.com, They have repair guides online now. You can try this direct link http://www.autozone.com/servlet/UiBroker?ForwardPage=az/cds/en_us/0900823d/80/0a/38/0a/0900823d800a380a.jsp
Old 05-23-2007, 03:24 PM
easygo's Avatar
easygo
easygo is offline
Lightbulb thanks
great links and info,I knew the rednecks would come thru.
Thanks
Ian
phoneman91
62
03-13-2024 09:16 PM
OlBrownTruck
04-27-2017 04:02 PM
armyaviation
03-25-2017 05:49 PM
78f150dent
09-23-2011 12:20 AM
Quick Reply: 95 F150 wiper motor removal
