95 F150 wiper motor removal - Ford Truck Enthusiasts Forums
Old 05-22-2007, 09:56 PM
easygo easygo is offline
easygo is starting off with a positive reputation.
Question 95 F150 wiper motor removal
Wiper motor on 95 F150 slowed then quit, have 93 E150 same 300 in line 6.are wiper motors interchangable.would anybody have diagrams or instructions on removal. Giving truck to son for 1st auto trying to fix few items.Any help appreciated.
Thanks
Ian
Old 05-23-2007, 07:12 AM
PhilcoPGM PhilcoPGM is offline
PhilcoPGM is starting off with a positive reputation.
F150 wiper motor replacement
I have a 93 F150 and the wiper motor doesn't work at all on any speeds. Can anyone give instructions on how to replace? Thanks in advance.
Old 05-23-2007, 07:54 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
You have to unbolt the trim piece behind the hood at the base of the windshield. The linkage and motor are under it.
Old 05-23-2007, 08:14 AM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
you may have to loosen hood to get cowl panel off to work on motor linkage. If you have problem get at arm bolt. Then like Conanski said . Good luck
Old 05-23-2007, 12:13 PM
Wingman69 Wingman69 is offline
Wingman69 is starting off with a positive reputation.
I changed my wiper motor on my 93 F150 a couple of weeks ago. It's somewhat easy to do, the hardest part was getting the linkage unhooked. Here are the general steps.
  1. Disconnect battery ground cable.
  2. Remove both wiper arm and blade assemblies.
  3. Remove cowl grille attaching screws and raise the grille slightly.
  4. Disconnect washer nozzle hose, then remove cowl grille assembly.
  5. Remove wiper linkage clip from motor output arm.
  6. Disconnect wiper motor electrical connector.
  7. Remove wiper motor attaching screws and the wiper motor.
  8. Reverse procedure to install.
It is a little tough getting the cowl grille out with the hood on, but just go slowly.(It might go easier with 2 people on that step.) Try not to beat or drop the new motor, there are ceramic parts in it that could break. A more detailed instruction can be found @ http://www.autozone.com, They have repair guides online now. You can try this direct link http://www.autozone.com/servlet/UiBroker?ForwardPage=az/cds/en_us/0900823d/80/0a/38/0a/0900823d800a380a.jsp
Old 05-23-2007, 03:24 PM
Lightbulb thanks
great links and info,I knew the rednecks would come thru.
Thanks
Ian
wipers work when not on GTBksRule Electrical Systems/Wiring 2 02-09-2013 08:16 AM
removing wiper motor help jpeckham 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 10-16-2011 09:00 PM
1978 F150 Wiper Switch/Motor/Washer Pump Wiring 78f150dent 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-23-2011 12:20 AM
Wiper cowl removal xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 9 02-20-2011 11:42 AM
Testing the Wiper Control Module n2wheelinxjs 1987 - 1996 F150 & Larger F-Series Trucks 2 01-05-2005 07:45 AM
Tags
93, 95, changed, f150, ford, linkage, motor, removal, remove, replace, replacement, truck, van, wiper, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
