Need Help with 400 block date code
Originally Posted by 78longbed
I found the C logo, next to it is what looks like a plate with a flat head screw at each end that is actually cast into the block. On the plate it has the numbers 2E4. The 2 has two dots under it, thats all that is there.
2 = 1972
E = May (Month cast is by alphabet, so A = Jan. C = March, etc.)
4 = 4th day.
May 4th, '72, 5-2-72.
I'm told earlier 351M/400 blocks are inferior compared to ones after 3/76 cast date.
It was casted at the Cleveland plant (I think).
Thanks, I bought the 400 complete for 60 bucks to replace the dying 351m. I don't know if I should try it, it has probably over 100k on it, I would have to switch pans and sump pick-up as it was out of a 2 wheel drive. I was told it was running probably over 5 years ago, it is not locked up, but under both valve covers there is a ton of sludge build up, pulled the pan lower end is fairly clean and the cylinders don't look scratched up from what I can see from the bottom. Of course it would need a timing chain set.
You ought to give it a compression test before you throw it in a truck.
If you don't see any metal shaving/pieces in the pan, then it should be OK. I'd check the valves. I haven't seen any untouched 351M/400 without sludge buildup. Did you pull up the intake manifold to see any sludge?
Buy an aftermarket three-way timing chain set and set it at 0, not factory -4. Should free up some muscle.
I am not 100% sure that it's 400, The guy I got it from said he was sure that it was, he mostly had 302's that he worked on, and seemed to know the engine lines. Are there any stampings that I could see on the crank? I haven't pulled the intake, I thought about leaving the engine on the stand turning it sideways and cleaning the heads with brake clean or gunk. It's got the old points dist. I understand that I could use the pointless one from the 351m. My real problem is my son needs sonething to drive quick. I have another 400 that is pretty much drop in condition with about 30k on it. It is for the other f250 frame that is in the driveway (that my wife isn't crazy about). I'm thinking that I should probably use the other projects 400 for now to get my son's truck going. Sorry to ramble on, I'm just looking for the quickest solution to get the truck going.
I think you can check the crank to see if it's a 351M or 400 crank. Don't hold to my word.
Yes, you can use the DuraSpark from the 351M. It will bolt up without issues. Just make sure to check the hex for wear.
I'd go with the drop-in 400 with 30k if your son needs something to drive as soon as possible. Why take chances?
TOM B1
08-08-2017 08:53 PM
adam83
41
08-20-2015 12:01 PM
