electrical relay 305 - trailer hot wire
If I remove the 305 relay, and install a jumper from terminal (87 - 30) I get a constant live terminal at the trailer plugin. Is this fused upstream in the wiring harness? Where is that fuse located? and what is it's rating? If not I will put in a breaker.
Are there any other items run off of this relay?
Is anything run off of the 87a terminal?
Trailer hot wire
Relay is good, I want to remove it so that I have a constant "live" feed.
Our horse trailer load/interior lights are connected to this circuit and is a pain to turn key on and off to run lights for the day.
This seemed like the best option to use unless there were some other circuits I wasnt aware of.....
For longer stays in the trailer we bring a deep cycle along to plug the trailer into.
Thanks for the help.
JamesF-250
13
08-18-2014 05:19 AM
