Extended maintenance plan???
Well lets look at the numbers:
12 x $55 = $660 oil & filter change
4 x $38 = $152 Fuel filter change
2 x $175 = $350 Trans flush & filter change
Total cost $1162.00
This is with you doing the work yourself. If you do your own oil & fuel filter changes but let the dealer do the transmission flush add $150. At the most you might need front break pads depending on your driving style, you change front break pads yourself for less than $100.
Hope this helps.
Total cost $1162.00
Hope this helps.
Originally Posted by BigF350
I would say yes...
Dealership services can be $$$
The only way you can beat that price - is to go to a Jiffy lube or the like - where they will put in cheap oil, use cheap filters. Honestly I wouldn't let them near my truck with a 40ft pole.
Thanks everyone, I ordered the warranty thru greenfield ford in ma, Troy was a great guy to work with, I ended up going with the 6 years, 75,000 mile maint. warranty, it was a little over $2,000.00. I think it will save me some money down the road, and at least I know Ford will stand behind the work!!!
