Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 Performance Ford F-150's
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 08-11-2007, 07:33 PM
minutofgroundhog's Avatar
minutofgroundhog is starting off with a positive reputation.
Thanks again guys, it started throwing lean codes on both banks so I did away with the whole system. ( and the truck was surging at WOT) Now I have a hose coming out of the valve cover going to atmosphere, no lights,no surge.
  #17 (permalink)
Old 08-12-2007, 07:50 AM
Silver Streak is gaining momentum as a positive member of FTE.
I don't us a separator, but had to do something to keep the big puff of smoke from coming out the exhaust on start up. What I found was a T in the PCV line on the passenger's side of the blower that actually allows compressed air to go into the crankcase through the PCV system. The T has one line that goes to the upper plenum, one that goes to the valvecover, and the third goes below the blower on the back of the engine. I removed the T and replaced it with a piece of vacuum hose that connects the vavlecover to the upper plenum. The line that goes to the rear of the blower is plugged. No more smoke and I haven't noticed anymore oil in the intake.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #18 (permalink)
Old 08-14-2007, 09:40 PM
mohead1 is starting off with a positive reputation.
I got an 03 Harley puffer, and it came with one of the low buck separators like you use on a compressor line, it fills up pretty quick after a couple of hard runs under boost. I got to empty the dang thing all the time. Looking for a better animal. The LFP unit (I think its theirs) has a return back to the valve cover I believe, but it is a monsterous looking thing that ties into the oil fill neck. Anyone got something similar but not connected like that? I got a lathe and Bridgeport, could probably cobble something up, mount on a high bracket and tie back into the motor. Thoughts??
Mo
  #19 (permalink)
Old 08-14-2007, 11:05 PM
I don't have a puff of smoke on startup (valve seals ? ) I know ford has factored it in...
but any air entering downstream of the MAF is un-metered air. Now the factory setup was designed to work a certain way, when I added a filter inline that screwed it all up. Thats why I think it was going lean,the PCV valve wasn't modulating like it supposed to and was just open sending "extra" air in with no extra fuel to balance. My next mod will be the EGR delete. But I need a programmer.... I do have a good lead on one though. Hopefully by this weekend.
  #20 (permalink)
Old 08-21-2007, 09:46 PM
lowflyingbird is starting off with a positive reputation.
Think about it !!!
I have a Expedition with a recent L SC setup. I'm a product designer, and thought the system out. Keep in mind that the plenum's a constant vacuum with the blower. If under stong vacuum, oil is sucked thru the tubing to the collector. Then either the collector holds the oil or it has a check valve to return the oil to the engine. If it has a check valve then it has to be so weak that even a small amount of oil can keep it open while not under vac.
Said, if your valve cover return type seperator is suposably working, How would you know? unless you pull your blower? Think, if your valve cover return type seperator has no (seen) check valve, then wouldn't the draining port become a suction port under vacuum????
I personally have a brand name (Speedair) oil seperator (air compressor type) inline with the lower intake drain line (thats what it is) Tee'd with the PCV going into the seperator. It collects a small bit of oil every say 2 weeks. Just enough for me to drain out of it into a rag. I'd figure > an ounce. BUT, no matter how you look at it, it's an ounce not going thru the sysyem killing your gases octane.
As for the user who mentioned the problem with using a filter and geting a code , and a lean fuel condition. That makes no sense!! filter or no filter it would be the same,no extra air being introduced. There must be some other issues their!!!!!!!!!
  #21 (permalink)
Old 08-22-2007, 04:45 PM
Only lean at WOT
Originally I capped the compressor drain line, and installed the oil separator.
Lean bank 1 & 2 popped after a few WOT runs. As long as I kept my foot out of it, no codes. So then I capped the plenum, and vented the valve cover to atmosphere. No codes no matter what. This is a stock 04 L with 35K mi.
Now it may not make any sense at all but thats my story......
And I did end up with a Predator, BIG improvement. I think those Ford engineers are too enviormentally sound ( too lean )
  #22 (permalink)
Old 12-18-2007, 09:48 AM
04markIII's Avatar
04markIII is starting off with a positive reputation.
Quote:
Originally Posted by 04markIII
i bought one on ebay several months ago. just had it installed last week finally. i paid about $40 shipped on ebay. http://cgi.ebay.com/ebaymotors/Ford-Lightning-Harley-Oil-Separator_W0QQitemZ150135308613QQihZ005QQcategoryZ 46098QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i already have oil in it, so im glad its there now.
sorry to hijack this, but does anyone have the cleaning instructions for this particular unit? i lost mine, and with the recent seafoam treatment, it's pretty nasty. thanks.
-jon
__________________
SUPERCHARGED 2003 Expedition Eddie Bauer: 03 harley supercharger, 6lb lower pulley, k&n panel filter, magnaflow catback exhaust. 339 RWHP, 440 RWTQ. lund window visors and bugshield, black headlights, eclipse 5510 head unit, autometer c2 cobalt boost gauge, white face gauges, f150 20" oem rims
  #23 (permalink)
Old 05-13-2008, 11:37 AM
budribbs's Avatar
budribbs is starting off with a positive reputation.
i got one from rpm a few months ago still junk
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
