Master Cylinder on a 1950 Ford - Ford Truck Enthusiasts Forums
Old 05-21-2007, 11:15 PM
chops1987 chops1987 is offline
chops1987 is starting off with a positive reputation.
When my grandfather passed a few years ago I inherited his fully restored 1950 ford (CAR). It has been stored in my grandmothers barn for the past 4 years, I hate to to say it but it has not been started since then. The time to bring it home to my own garage is coming closer and I went to peak at it the other day and relized there is no brakes. I would like to check the brake fluid and I know that the master cylinder is under the floorboard. I just have to unscrew a plate under the carpet to get at it right? Im thinking it either has no brake fluid or possibly the master cylinder and wheel cylinders have set up. When you push the pedal down it takes a little bit of time for it to come back to position. ANyone have any insight? Also, how might I go about starting this when it comes time. I was thinking id drain the old gas out of it, put in some new and maybe spray some starting fluid down the carb. Any suggestions or help is greatly appreciated. Thanks all.
Old 05-22-2007, 05:49 AM
old fool old fool is offline
old fool is starting off with a positive reputation.
Yep, the master cyl. is sticking-AT LEAST. You'll probably end up replacing it as well as all wheel cylinders. Good time to consider a dual setup (much safer). I would be wary of all the old brake parts including lines. As for starting, clean the points, check the carb, replace the gas, and have a fire extinguisher handy. Also look for wires that may have been chewed by mice.
Old 05-22-2007, 05:56 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
You are probably right about the wheel cylinders. They have probably seized due to corrosion in the brake system which is common for vehicles that sit for that long. Drain the gas, radiator, and oil and put in new fluids before trying to start it. I'd also check the points to be sure they are opening and closing.
Old 05-22-2007, 08:11 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1950 Ford Passenger Car
1-The 6 Volt Battery is: GROUP 2L The battery is POSITIVE GROUND
8-AL-7 .. Spark Plugs
1-C9AZ-12171-B .. Points (Motorcraft DP-3)
1-FAA-12200-A .. Rotor (Motorcraft DR-1)
7RA-12300-C .. Condenser (Motorcraft DC-6)
1-7HA-12106 .. Distributor Cap (Motorcraft DH-4)
1-A9A-2140-A .. Master Cylinder
1-A9A-2004-A .. Master Cylinder Repair Kit
1-1A-2162-A .. Gasket, Master Cylinder Cap
2-C3AZ-2128-A .. Rear Wheel Cylinder Kit 7/8"
2-D8UZ-2221-A .. Front Wheel Cylinder Kit 1 1/8"
1967 F100 Brake Pedal Seized Hard wramos 1967 - 1972 F-100 & Larger F-Series Trucks 25 06-03-2015 09:27 AM
Brake Fluid Pushing Out the Master Cylinder Yellow79F100 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-14-2014 07:07 PM
1950 Ford F1 Resurection 1950FordF1 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 01-27-2014 07:38 PM
1950 F6 brakes chicken1 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-08-2013 12:05 PM
DOT 3 vs DOT 5 brake fluid BR F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 11-01-2009 06:19 PM
Tags
1950, 7ha12106, 7ra12300c, a9a2140, brake, cylinder, dh4, fluid, ford, ha12106, master, motorcraft, regular, synthetic, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
