Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-21-2007, 08:52 PM
wiingnut's Avatar
wiingnut wiingnut is offline
Garage is empty, add now
wiingnut is gaining momentum as a positive member of FTE.
Has anyone used B-10?
I have an 05 6.0 L. When I got my truck I found a paper where Ford Motor stated they only recommend B-5 as a useable biofuel, with the diesel for various reasons. Does anyone know if they changed their stance. I went to a Pilot station yesterday and they only had B-10. I went elsewhere. Any info would be great. Thanks
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP w/ Fac Nav and rear DVD
12 Escape Limited
  #2 (permalink)
Old 05-21-2007, 09:26 PM
Fraalan Fraalan is offline
Fraalan is starting off with a positive reputation.
b-5 or b-10 doesnt make a difference.
It will probably run better than b-5, quieter and 1% less power.
__________________
2003 F250 SD, CC, 7.3, FX4, HPX, AIS, Zoodad, CCV Trap, 6.0 intercooler, 6.0 - 31 row tranny cooler, coolant filter,AIH delete, dp-tuner, 6.0 air intake
2003 Excursion V10 with Headers 2X4
  #3 (permalink)
Old 05-22-2007, 08:02 PM
wiingnut's Avatar
Thanks for the info
__________________
12 Escape Limited
  #4 (permalink)
Old 05-22-2007, 08:07 PM
Murphy2000 Murphy2000 is offline
Murphy2000 is starting off with a positive reputation.
Most of the reason why engine manufactures do not recommend higher concentrations than what they do, has nothing to do with the engine and the fuel..
it has to do with emissions out the tail pipe.
Biodiesel increases NOx emmisions just a bit over the EPA limit. The EPA holds the engine manufacturers responsible not the fuel makers.
Because of this, until they modify the engine exhaust scrubbing to meet the EPA standards, they don't recommend higher blends.
Its a bunch of horse hockey.
Your engine will run better and longer on B100 than any dino diesel.
  #5 (permalink)
Old 05-23-2007, 07:50 PM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
i have the same engine/truck and have run all blends and try to run b100 as much as possible. If I had my choice i would only run b100, weather permiting, but sometimes my bio distributor isn't available or is out of fuel for a day so I have to put a couple gallons of D2 in the truck. Your truck will run perfect on biodiesel, just beaware your fuel filters my get clogged fast and if they get really clogged your injectors will starve for fuel which is very bad.
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
  #6 (permalink)
Old 05-23-2007, 07:58 PM
wiingnut's Avatar
thanks for the info guys
__________________
12 Escape Limited
  #7 (permalink)
Old 05-23-2007, 09:07 PM
I fill up on b-99 and then fill up at a half tank with dino for b-50 to avoid going to the "hood". Then I will even fill up with dino again at quarter tank to run the bio as long as possible.
__________________
  #8 (permalink)
Old 05-23-2007, 09:13 PM
wiingnut's Avatar
Have you seen a mileage increase?
__________________
12 Escape Limited
  #9 (permalink)
Old 05-23-2007, 10:51 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
The only real possible problem you may have, is carbon deposits building up at or near the piston rings, since biodiesel has a higher ignition resistance compared to the dino variety. This is generally considered to be a problem with direct injection (as apposed to indirect) since the bio fuel is more likely to reach the piston unburned without a prechamber for premixing.
Now this is only a general rule and is based on older direct injected diesels that had lower pressure injectors that didn't atomize the fuel as well as the newer injection systems, such as the ones used in powerstrokes.
I wish they sold B100 or B-anything where I live, the older injection systems don't hold up very well on strait LSD or ULSD (I have to run additive).
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
