Bio-D mixed with Diesel
Old 05-20-2007, 06:43 AM
tommyl's Avatar
tommyl
tommyl is offline
Can you mix (say) a half tank Bio-diesel with a half tank of regular Diesel fuel?
Old 05-20-2007, 07:28 AM
fellro86's Avatar
fellro86
fellro86 is offline
yes, that would make B50...
Old 05-22-2007, 01:21 AM
ajf99ford's Avatar
ajf99ford
ajf99ford is offline
what about in this warm weather now in Pa. I want to mix 60% Diesel and 40% Filtered Veggie Oil. That should be ok........right ???
Old 05-22-2007, 06:09 AM
fellro86's Avatar
fellro86
fellro86 is offline
The veggie oil separates out. It also needs to be heated to 180 degrees to achieve it's flash point. If you don't preheat the veggie, it can cause the injectors to coke up.
Old 05-22-2007, 03:35 PM
ajf99ford's Avatar
ajf99ford
I know about those heating setups with a seperate tank and coolant running around the fuel lines. But in the warm weather can I just put one of those Racor 12Volt heated filter units in line with my fuel system and use 60% diesel and 40% Filtered Veggie oil.
thanks
Andre'
Old 05-22-2007, 04:04 PM
fellro86's Avatar
fellro86
fellro86 is offline
Do yourself a little test... take a little diesel, and an equal amount of veggie oil, put them in the same glass jar, and let it sit. This will show you if the oils will separate. I did it and they did. Also, any natural rubber hose or seals will become mushy after running it like that, veggie is hard on rubber parts.
Old 05-23-2007, 02:28 AM
ajf99ford's Avatar
ajf99ford
thanks fellro86, you know what had me most frustrated, I performed small test batches to make some Bio diesel. The Glycern settled out and it looked great, but I put them in the fridge overnight in a mason jar and they gelled up. To me it seemed like I will have to heat up no matter what I put in except diesel.
thanks again
Andre'
Old 05-23-2007, 05:59 AM
fellro86's Avatar
fellro86
fellro86 is offline
Yes, that's a downfall of bio, it gels too easy.
Bounds-Electric
6.4L Power Stroke Diesel
10-03-2011 02:33 PM
halaferd
10-03-2011 01:53 AM
drewdole
01-27-2010 06:46 PM
astarner74
12-19-2009 02:13 PM
tazo
Bio-diesel, Propane & Alternative Diesel Engine Fuels
12-05-2007 09:06 PM
Quick Reply: Bio-D mixed with Diesel
