You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Is there anything on the market to convert a non-flex fuel vehicle to run on E85? We have an 03 Expedition I'd like to convert as well as a couple of non-Fords.
Are you looking to convert to run straight E85, or make it flex fuel? Because making it flex fuel is a whole lot more difficult and / or costly than simply converting it to run E85.
Have to do a search, but I believe some were posted a while back that were legal with restrictions... mostly intended for older vehicles. EPA is still not approving any non-OEM stuff very well... at least not a t a reasonable price tag...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
I would be curious to know just how propane and ethanol as well as methanol are "dirtier" by emissions standards...
__________________
It isn't the fuels that are the problem -- it's the conversion kits. What they seem to be sayiing is
1. Nobody seems to be submitting kits for EPA approval
2. Approval is probably expensive, because you have to prove that the system will work correctly for a bizillion miles -- and that you will fix it if it doesn't
You can have various types of pollution with anything -- if you burn it wrong. So, somebody needs to prove to the EPA that their kit will work the way that it's supposed to.
I'm guessing that it comes down to $$$. Nobody can figure out how to make enough money selling kits to justify the expense of getting them approved.
And, they'd probably have to be approved separately for each application. And, of course, the auto companies would try to void any warranty on a converted vehicle. (Yes, there's a law, but they'd try).
If the engine is not calibrated correctly for the different fuel, the air-fuel mixture and timing will be "off" and emissions will be higher. If the injectors are too small, the O2 sensor and computer physically cannot sufficiently correct the mixture, leading to lean misfire. There is an optimum timing curve that somewhat depends on flame front speed within the cylinder and that varies slightly with different fuels.
Propane conversions that I have seen are very "crude" compared to a stock gasoline injection system.
__________________
B5 soydiesel user
Sirius radio
