Before you recharge it, peel the foam off of the accumulator (the metal can that has the low side connection). If you see rust, you will have to replace it. They rust through and leak the refrigerant out quickly.
You really should find where your leak is and fix it regardless. Leaks only get worse.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken! www.lakeshorerailway.org
