Broken driveshaft in landing gear - Ford Truck Enthusiasts Forums
Old 05-21-2007, 10:48 AM
mel2000f150 mel2000f150 is offline
mel2000f150 is starting off with a positive reputation.
Well, this weekend I broke the driveshaft in my landing gear.
2005 rockwood 5er. called ATWOOD and they think it was defective shaft, not something that I did. Anybody else broke theirs.
Old 05-21-2007, 11:08 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
I have a '94 Prowler 5ver. My front landing gear 'clutch' broke not long after it was new. Prowler send me a new one at no charge, 1 year warranty was up. My gear drive shaft was ok. Over the years, I have had to replace the 90 degree angle gears because of much wear because of poor lubrication tho....
Old 05-22-2007, 06:02 PM
firesoutmatt's Avatar
firesoutmatt firesoutmatt is offline
firesoutmatt is starting off with a positive reputation.
Funny you should ask this question. This weekend my extend wouldn't extend but would retrack. Got out the manual crank and quess what it was the wrong one from the factory. The crank has an end that is round with a slot cut into it and my shaft has a hex on the end. Dooh I kept messing with it and finally got the extend to extend far enough to get hooked back up. If it didn't I don't know how I would have got it hooked back to my truck. Called factory today and see what they say.
Does your manual crank have the slot or a hex on the end ?
Old 05-23-2007, 06:40 AM
The landing gear has a slot. The slider has a hex drive.
Tags
5th, 94, gear, landing, makes, prowler, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
