DTC P1000 - Few weeks...Worry?
Old 05-20-2007, 10:54 PM
awu_gigabyte's Avatar
awu_gigabyte
awu_gigabyte is offline
Hey i just decided to do a DTC check on my truck and its getting p1000. I went back to stock with my edge, i drove around a buddies 06 and surprisingly missed the way it used to be.
This was about 2 or 3 weeks ago, now i've read this should go away with a few drive cycles, but i've probably had hundreds in the past 3 weeks. Should i be worried?
Thanks,
Rob
Old 05-21-2007, 08:06 AM
Corey872's Avatar
Corey872
Corey872 is offline
Maybe need a little clarification on what constitutes a 'drive cycle'...unlikely you would have done this hundreds of times in the past couple of weeks, but this is what it may need
http://www.obdii.com/drivecycleford.html
Old 05-21-2007, 11:21 AM
awu_gigabyte
So, do i really need to follow all of those instructions just to clear this code? Or should i just leave it be and have it clear up on its own?
Thanks,
Rob.
Old 05-21-2007, 11:51 AM
06Stallion's Avatar
06Stallion
06Stallion is offline
you will eitherneed to follow the instructions or take it back to a dealership and have themclear it with theres. the lightning threw that one after I diconnected the battery and had to take it to get cleared. just remember to flash back to stock if you do.
Old 05-21-2007, 11:52 AM
awu_gigabyte
Yea, but what if i just leave it? Any harm done?
Old 05-21-2007, 07:33 PM
ohboy44's Avatar
ohboy44
ohboy44 is offline
P1000 shows up almost every time you check codes. There is nothing wrong with your truck.
Old 05-22-2007, 12:49 PM
06Stallion's Avatar
06Stallion
there is no harm at all.
Old 05-22-2007, 12:51 PM
awu_gigabyte
Thanks for the info!
Old 05-22-2007, 01:34 PM
Ulf's Avatar
Ulf
Ulf is offline
awu_gigabyte,
I was worried about the same thing, I have to get my truck NY State inspected in June so I went back to stock tune about three weeks ago and my truck was showing P1000 code, I removed my Edge for the time being, after two weeks it still showed P1000 so I was a little bit worried, well today I checked the code with my Edge again, temporairly plugged it in and the code was cleared....
I might be wrong but I think that every time you change from stock tune, #1, #2, #3 or back to stock tune, it resets the computer and causes the P1000 code to be set again and the computer has to relearn.
The problem with the NYS inspection is they plug a cable into the diagonstic port on the truck to check for any codes and if it has one it won't pass inspection, the service facilitys computer is tied into NYS Department of Motor Vehicles system and any vehicle from 1996 and newer must have this done......
I don't know if lets say I had my truck set on tune #2 "Towing Mode" with no codes if it would pass inspection or not.......???
Old 12-01-2009, 04:03 PM
Jayson250's Avatar
Jayson250
Jayson250 is offline
i just changed my ficm out because i was getting different codes now i have p1000 and u0306 i changed the computer back to stock before swapping them out and then put the new one to the tune i had before can i just clear these most guys say there nothing wrong just wondering if you guys have any insight thanx again
Old 09-16-2011, 01:51 AM
jbellows's Avatar
jbellows
jbellows is offline
Won't pass unless p1000 is gone, no matter what tune your running
jimjokjv
08-02-2017 06:59 PM
Duck410
04-11-2017 10:12 PM
rustyandleaking
12-30-2016 01:16 PM
AGrayson84
1997-2006 Expedition & Navigator
11-01-2016 09:35 AM
chucky2
04-06-2016 01:16 AM
Quick Reply: DTC P1000 - Few weeks...Worry?
