DTC P1000 - Few weeks...Worry? - Ford Truck Enthusiasts Forums
Old 05-20-2007, 11:54 PM
awu_gigabyte awu_gigabyte is offline
awu_gigabyte is starting off with a positive reputation.
Hey i just decided to do a DTC check on my truck and its getting p1000. I went back to stock with my edge, i drove around a buddies 06 and surprisingly missed the way it used to be.
This was about 2 or 3 weeks ago, now i've read this should go away with a few drive cycles, but i've probably had hundreds in the past 3 weeks. Should i be worried?
Thanks,
Rob
Old 05-21-2007, 09:06 AM
Corey872 Corey872 is offline
Corey872 is starting off with a positive reputation.
Maybe need a little clarification on what constitutes a 'drive cycle'...unlikely you would have done this hundreds of times in the past couple of weeks, but this is what it may need
http://www.obdii.com/drivecycleford.html
Old 05-21-2007, 12:21 PM
So, do i really need to follow all of those instructions just to clear this code? Or should i just leave it be and have it clear up on its own?
Thanks,
Rob.
Old 05-21-2007, 12:51 PM
06Stallion 06Stallion is offline
06Stallion is starting off with a positive reputation.
you will eitherneed to follow the instructions or take it back to a dealership and have themclear it with theres. the lightning threw that one after I diconnected the battery and had to take it to get cleared. just remember to flash back to stock if you do.
Old 05-21-2007, 12:52 PM
Yea, but what if i just leave it? Any harm done?
Old 05-21-2007, 08:33 PM
ohboy44 ohboy44 is offline
ohboy44 is starting off with a positive reputation.
P1000 shows up almost every time you check codes. There is nothing wrong with your truck.
Old 05-22-2007, 01:49 PM
there is no harm at all.
Old 05-22-2007, 01:51 PM
Thanks for the info!
Old 05-22-2007, 02:34 PM
Ulf Ulf is online now
Ulf is starting off with a positive reputation.
awu_gigabyte,
I was worried about the same thing, I have to get my truck NY State inspected in June so I went back to stock tune about three weeks ago and my truck was showing P1000 code, I removed my Edge for the time being, after two weeks it still showed P1000 so I was a little bit worried, well today I checked the code with my Edge again, temporairly plugged it in and the code was cleared....
I might be wrong but I think that every time you change from stock tune, #1, #2, #3 or back to stock tune, it resets the computer and causes the P1000 code to be set again and the computer has to relearn.
The problem with the NYS inspection is they plug a cable into the diagonstic port on the truck to check for any codes and if it has one it won't pass inspection, the service facilitys computer is tied into NYS Department of Motor Vehicles system and any vehicle from 1996 and newer must have this done......
I don't know if lets say I had my truck set on tune #2 "Towing Mode" with no codes if it would pass inspection or not.......???
Old 12-01-2009, 05:03 PM
Jayson250's Avatar
Jayson250 Jayson250 is offline
Jayson250 is starting off with a positive reputation.
i just changed my ficm out because i was getting different codes now i have p1000 and u0306 i changed the computer back to stock before swapping them out and then put the new one to the tune i had before can i just clear these most guys say there nothing wrong just wondering if you guys have any insight thanx again
Old 09-16-2011, 02:51 AM
jbellows jbellows is offline
jbellows is starting off with a positive reputation.
Won't pass unless p1000 is gone, no matter what tune your running
2004 Ford E250 4.6 V8 trouble codes rustyandleaking 1968-2013 Full Size Vans 3 12-30-2016 02:16 PM
P2195, P0059, P1000, P0330, U0121, P0351... so many codes!! Please help!!! AGrayson84 1997-2006 Expedition & Navigator 4 11-01-2016 10:35 AM
2000 Expedition: DTC B1998 Passenger Airbag chucky2 1997-2006 Expedition & Navigator 4 04-06-2016 02:16 AM
P1000 DTC Clearing dsquared 1999 - 2003 7.3L Power Stroke Diesel 5 10-11-2011 06:49 PM
DTC Help btsb032304 6.0L Power Stroke Diesel 11 07-24-2008 10:36 AM
Tags
2008, changing, clear, code, codes, dtc, dtcp1000, dtcs, f150, f350, ford, lightning, obd, p1000, tune
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
