Trailer wiring F350 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Trailer wiring F350
Old 05-20-2007, 11:26 AM
hjesq hjesq is offline
hjesq is starting off with a positive reputation.
Trailer wiring F350
I understood that some Super Duty trucks came pre-wired for trailer brake installation. I installed the trailer brake controller to the quick plug under the dash to the right of the steering column. When I check the brake feed comming from the controller (blue wire) the little green light on the contoller lights up. This would indicate that it is properly installed (I think).
I then installed a Hoppy trailer plug (Part #40165) at the back of the vehicle and checked that the wire color and function matched. No such luck, the blue wire at the rear of the vehicle which should be the trailer brake, is now a brake lite.
I want to wire a 7 pin trailer plug to the #40165. Can anyone help, I'm really confused.
HE
Old 05-20-2007, 11:47 AM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
First according to what I can find the hoppy 40165 is a 4 wire trailer hookup not the 7 way blade.
Second, what do you mean the blue wire is a brake light? The blue wire should get voltage whenever the brake pedal is pressed in the truck, that is how the electric brakes work. The actual brake lights for trialer wiring are wired seperate for the left and right sides (red and brown). That is what allows the flashers to work.
Here is a link to a page that shows what wire color is what, and what blade is what.
http://www.rverscorner.com/wiring/7pole.html
Old 05-20-2007, 04:09 PM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
hjesq,
Make sure the fuses and relays are installed in the under-hood junction box, drivers side adjacent to master cylider. Look in your owners manual for location and auxillary fuse block description.
Hope this helps
Old 05-20-2007, 06:03 PM
I will check the fuses and relays, Thanks. Beerstalker your right, the blue wire should only have voltage when the brakes are applied. The voltage should increase as the brake adjuster is increased from low to maximum. However in this case my testlight shines brightly as soon as the brake is applied. I will check the actual brake light (red and brown) for current. The 40165 conector has a four pin connector as well as an additional blue and red wire. Thanks for your help, I will keep trying!!
HE
Old 05-20-2007, 06:07 PM
Just checked the submitted wiring diagram. It appears the wire color is different in Canada. Still working at it.
HE
Old 05-21-2007, 12:46 PM
hjesq, if you are trying to add a 7 way rv plug why not just buy ont that plugs directly in, rather than taking the 4 way harness you have and cutting it up? Draw-tite makes a harness 118243 that I know works on the 99-01 super duty, I am pretty sure it will work for your truck too. You can usually get it at the local U-haul place or trailer stores for $35-60US.
Trailer wiring fixnair 1999 to 2016 Super Duty 4 06-06-2015 10:57 PM
Trailer brake wiring greenheads Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 22 05-25-2015 05:36 PM
F250 Trailer Brakes captnko Brakes, Steering, Suspension, Tires, & Wheels 5 05-29-2012 06:08 PM
Wiring a Trailer Tow Battery jonesn4fun Electrical Systems/Wiring 1 10-24-2011 07:06 PM
help, trailer brakes locked up when plugged in 97XLT4X4 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 20 03-25-2011 05:24 AM
Tags
350, 92, colors, diagram, duty, f350, ford, grounding, harness, hook, problem, super, trailer, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
