48-52 Frames: are tehy the same?
I am looking for a 48-52 frame if they are all the same. I want to make the coe into more of a cruiser, now that I have road in the big truck.
Will the cab mounts be in the same place from a F6 to a F1?
I then will have a big tow truck and a cruiser coe. I hope to be done by next years Nationals.
Tell me the pitfalls and drawbacks. Tomoto what do you think. Now I really need to visit you!
Hey Ksmith i'm not to sure but can check for you. tomoto will be the best one to answer this, anyways are you still in knoxville? Sorry i couldn't make it to dinner and tell everybody else sorry for not getting to meet them had to rush off right after I talked to you. One of the differences of the f-1 and f-6 frame is the steering column's are mounted different or so I'm told, but I'll check that also. JOE
F-1 on the green with Mll front with I would not do again and Dodge dakota on the 4 door with is what I would do again. But with the Mll front end you can lower the motor down so low that you can use the engine cover...the Dakota the rack and pinion is in the right place and angle,which makes nice,but the engine has to sit higher ,unless you put the motor in back ..front wheel drive would be nice .All in the bed and it would be so easy to work on
CruzerDog
03-05-2014 09:06 PM
abqrb2000
05-08-2013 04:31 PM
49fordpickumup
08-08-2011 10:11 PM
ksmith203
05-26-2007 11:37 AM
