Brake rotors
Brake rotors
Hi and thanks to any who can help. I've watched this site for a year now and got some very valuable info but I've never had the need to post before. I have a 96 with 4 wheel drive and I'm doing a front brake job. I've removed the caliper and hub after going to the parts store 3 times to get the correct size hub socket. Now I'm trying to figure out how to remove the rotor from the hub. Is it pressed on or does the hub have to be replaced as well? Thanks.
I agree with Cuda-Slim.
Cowboy Steve
*I, Cuda_jim, nor Club FTE assume any responsiblity for over-torqued studs, broken bolts, split knuckles, loss of front hub assembly while driving, so on and so fourth. You assume all responsibility for mods or procedures preformed by yourself or those you seek out. You are preforming this work at your own risk and we strongly recommend the use of eye, ear and hand protection.*
Cowboy Steve
clearsound, i plan on replacing rotors in the next couple of weeks and i was told to just pound out the wheels studs to separate the two. i imagine that it will still take some prying, beating, swearing, resting, repeating etc. to separate them. report back how it goes, i am interested to see how tough it's gonna be.
After getting the hubs off using a pick and a small hammer (hate that round nut, Does anybody have a tool that fits it?). You can beat the studs out of the hub and rotor and they should just fall apart. They did on mine. Then to put back together pound the studs back into both using a BIG hammer and a punch (so you don't hit the rotor accidently). It is not really a bad job except for that @#$^#&@! nut. Did I mention that I hate that thing
It has been about a year since I did it so memory is cloudy. Yes I remember the two nuts and vaguely remember how the lock washer worked but I believe one of the nuts was as I described. I remember once I got it loose enough to spin it I took a test light and stuck it in one of the holes and spun away till it came all of the way out.
