Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-20-2007, 06:43 AM
tommyl tommyl is offline
tommyl is starting off with a positive reputation.
Bio-D mixed with Diesel
Can you mix (say) a half tank Bio-diesel with a half tank of regular Diesel fuel?
  #2 (permalink)
Old 05-20-2007, 07:28 AM
fellro86's Avatar
fellro86 fellro86 is offline
fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE.
yes, that would make B50...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, NV4500 with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 05-22-2007, 01:21 AM
ajf99ford ajf99ford is offline
ajf99ford is starting off with a positive reputation.
what about in this warm weather now in Pa. I want to mix 60% Diesel and 40% Filtered Veggie Oil. That should be ok........right ???
__________________
1999 F-250 SuperDuty, 7.3 Powerstroke Diesel
4X4 99,000 miles
  #4 (permalink)
Old 05-22-2007, 06:09 AM
fellro86's Avatar
The veggie oil separates out. It also needs to be heated to 180 degrees to achieve it's flash point. If you don't preheat the veggie, it can cause the injectors to coke up.
__________________
Iowa Chapter leader
  #5 (permalink)
Old 05-22-2007, 03:35 PM
I know about those heating setups with a seperate tank and coolant running around the fuel lines. But in the warm weather can I just put one of those Racor 12Volt heated filter units in line with my fuel system and use 60% diesel and 40% Filtered Veggie oil.
thanks
Andre'
__________________
4X4 99,000 miles
  #6 (permalink)
Old 05-22-2007, 04:04 PM
fellro86's Avatar
Do yourself a little test... take a little diesel, and an equal amount of veggie oil, put them in the same glass jar, and let it sit. This will show you if the oils will separate. I did it and they did. Also, any natural rubber hose or seals will become mushy after running it like that, veggie is hard on rubber parts.
__________________
Iowa Chapter leader
  #7 (permalink)
Old 05-23-2007, 02:28 AM
thanks fellro86, you know what had me most frustrated, I performed small test batches to make some Bio diesel. The Glycern settled out and it looked great, but I put them in the fridge overnight in a mason jar and they gelled up. To me it seemed like I will have to heat up no matter what I put in except diesel.
thanks again
Andre'
__________________
4X4 99,000 miles
  #8 (permalink)
Old 05-23-2007, 05:59 AM
fellro86's Avatar
Yes, that's a downfall of bio, it gels too easy.
__________________
Iowa Chapter leader
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
