adjusting transmission bands
05-19-2007, 10:11 PM
on
I need to know how to adjust the second gear band in my 1994 ford explorer which has an A4LD auto tranny!
05-20-2007, 07:49 AM
10' lbs, back off 2 turns.
05-20-2007, 07:30 PM
on
do i screw it all the way in, torque to 10' lbs, and then back out 2 turns
05-20-2007, 08:40 PM
05-20-2007, 08:55 PM
on
well thanks you very much. Im going to do that first thing in the morning. I did adjust the band somewhat and the second gear is still slipping a little but if i screw it all the way in then out 2 turns that should stop that.
05-20-2007, 09:04 PM
It must be torqued to 10'lbs, then backed off from there.
05-21-2007, 07:36 AM
on
I went and did exactly what u said but now the second gear is not working at all, should i screw it out some more or screw it in?
05-21-2007, 07:41 AM
Leave it well enough alone.
There is obviously a problem that needs to be corrected.
05-21-2007, 09:14 AM
on
yeah i think i might. I cant seem to screw that stud/adjuster bolt in far enough to get any torque on it. I would assume this means the second gear band is gone and needs to be repaired?
05-21-2007, 10:02 AM
usually once a trans starts slipping it needs a new band and maybe other parts as well.
it is probably a combination of things worn out.
sounds like new transmission time, sorry.
05-24-2007, 07:45 PM
on
I was wondering if the servo could be doing this weird problem??
05-24-2007, 09:09 PM
" I cant seem to screw that stud/adjuster bolt in far enough to get any torque on it. I would assume this means the second gear band is gone and needs to be repaired "
If you are unable to screw the adjuster in far enough to get the correct torque the servo is not the problem.
arkredneck
1978 - 1996 Big Bronco
10-20-2015 03:39 PM
allwthrrider
10-08-2015 07:45 AM
mfp4073
1983 - 2012 Ranger & B-Series
06-02-2010 05:35 PM
kelvis
04-01-2006 07:52 PM
78fordman
11-03-2003 04:19 PM
1994,
1999,
2004,
adjust,
adjusting,
adjustment,
band,
bands,
broken,
exploer,
explorer,
f150,
ford,
gear,
transmission,
truck
