adjusting transmission bands - Ford Truck Enthusiasts Forums
Old 05-19-2007, 11:11 PM
adam_harding1234 adam_harding1234 is offline
adam_harding1234 is starting off with a positive reputation.
I need to know how to adjust the second gear band in my 1994 ford explorer which has an A4LD auto tranny!
Old 05-20-2007, 08:49 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
10' lbs, back off 2 turns.
Old 05-20-2007, 08:30 PM
do i screw it all the way in, torque to 10' lbs, and then back out 2 turns
Old 05-20-2007, 09:40 PM
yes, that is correct.
Old 05-20-2007, 09:55 PM
well thanks you very much. Im going to do that first thing in the morning. I did adjust the band somewhat and the second gear is still slipping a little but if i screw it all the way in then out 2 turns that should stop that.
Old 05-20-2007, 10:04 PM
It must be torqued to 10'lbs, then backed off from there.
Old 05-21-2007, 08:36 AM
I went and did exactly what u said but now the second gear is not working at all, should i screw it out some more or screw it in?
Old 05-21-2007, 08:41 AM
Leave it well enough alone.
There is obviously a problem that needs to be corrected.
Old 05-21-2007, 10:14 AM
yeah i think i might. I cant seem to screw that stud/adjuster bolt in far enough to get any torque on it. I would assume this means the second gear band is gone and needs to be repaired?
Old 05-21-2007, 11:02 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
usually once a trans starts slipping it needs a new band and maybe other parts as well.
it is probably a combination of things worn out.
sounds like new transmission time, sorry.
Old 05-24-2007, 08:45 PM
I was wondering if the servo could be doing this weird problem??
Old 05-24-2007, 10:09 PM
" I cant seem to screw that stud/adjuster bolt in far enough to get any torque on it. I would assume this means the second gear band is gone and needs to be repaired "
If you are unable to screw the adjuster in far enough to get the correct torque the servo is not the problem.
Adjusting C6 Intermediate Brake Band allwthrrider Clutch, Transmission, Differential, Axle & Transfer Case 10 10-08-2015 08:45 AM
band adjustment cheeks1 Mid-West Region 0 08-15-2007 07:56 PM
Ranger 4R44E Band adjustment Schedule Rjslater Ranger & B-Series 0 10-09-2006 06:18 PM
A4LD Band Adjust goose213 Clutch, Transmission, Differential, Axle & Transfer Case 1 11-11-2005 03:08 PM
band adjustment on e40d 78fordman Clutch, Transmission, Differential, Axle & Transfer Case 1 11-03-2003 05:19 PM
Tags
1994, 1999, 2004, adjust, adjusting, adjustment, band, bands, broken, exploer, explorer, f150, ford, gear, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
