2.5L 4-cyl Engine/Chamber Dimensions - Ford Truck Enthusiasts Forums
Old 05-19-2007, 07:50 PM
Pinhead-227 Pinhead-227 is offline
Pinhead-227 is starting off with a positive reputation.
I've got a '98 Ranger with a 2.5L 4-cylinder engine that needs a bit more power. I'm trying to do it as inexpensively as possible, so I need to know a few specifics before I decide exactly what I'm going to do.
Is this an interference engine?
What is the piston-valve clearance?
What is the combustion chamber volume?
Are stock pistons dished, domed, or flat topped?
Old 05-21-2007, 03:11 AM
BTT
After running roughly a half-tank through my pickup, I'm getting ~30mpg in town. Not bad, I suppose, but I'd like to push that into the 40 range or so. Shouldn't be too tough...
Using various mods, such as PowreLynz, PowreRingz, Singh Grooves, Edging, high(er) compression, and ECU tuning, 40 mpg should be a daily figure.
www.fueleconomytips.com
www.mpgresearch.com
Old 05-21-2007, 09:02 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Well it is not an interference engine, and I think they all have flat top pistons.
check this one out as a 2.5 is a stroked 2.3:
http://www.ford-trucks.com/forums/sh...6&goto=newpost
tom
Old 05-21-2007, 08:42 PM
That gives me a lot of information, but nothing specific.
Does anyone know how much can be shaved off a stock 2.3/2.5 cylinder head before hitting water? I want to get to ~10.5:1 compression...
Old 05-21-2007, 09:58 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
10.5:1 is not problem. The 2.3 heads can be shaved as much as .200, maybe more. Racers cut them well into the manifold bolt holes. If you cut too much, it will throw the cam timing off, so you would have to use an adjustable timing gear. Pistons are flat on the 2.3, don't know about the 2.5 jd
Old 05-21-2007, 11:39 PM
Cool! Where would I go to get a low cost adjustable timing gear? The cam is belt driven so I'm guessing the timing "pulley" is what I'd be changing? I've worked on OHV engines but this is my first OHC...
Old 05-22-2007, 07:53 AM
Racer Walsh used to have adjustable cam gears.. I think
tom
Old 05-22-2007, 02:08 PM
Old Rob Old Rob is offline
Old Rob is starting off with a positive reputation.
The 2.3/2.5 liter lima engine IS an interference, not by much, however enough. The pistons are cast flat top for NA and forged dished for Turbo's. I've never seen a stock 2.5 turbo engine thou. To get to a specific CR you need to know exactly what you have. The factory number is bogus and if you measure it, you'll find it to be higher than produced. On the KB piston site there is a compression formula that you can use.
Old 05-22-2007, 03:59 PM
So to know what I have I would need to tear the engine down and make some measurements. If the engine is already slightly interference (without valve-piston contact) what would be needed to raise the compression? If I were to shave 0.18" off the head, would I also have to cut valve reliefs in the pistons?
Old 05-22-2007, 08:57 PM
Quote:
At least check them and see what you've got to be safe. You'll want .090 on the exhaust and .060 on the intakes. If you're running an adjustable gear then check it retarded and advanced.
Old 05-23-2007, 08:11 AM
Well, someone should tell the rest of the world that the 2.3 is interference, as all I have read says not. I have not checked with a running engine. Heh. Nor have I checked with one taken apart, so I have no personal knowledge.
The Gates Rubber Co web site has a PDF file of engine timing belts with indication to their interference status, and that was one of my sources of 'knowledge', and the one I would go back to most.
tom
Old 05-23-2007, 01:04 PM
tom
I have thru the years run into some (not many) that after throwing the belt, had to remove the head and change a slightly bent valve. I t has happened. In this thread discussion is to mill the head for more compression, which will bring things closer together. It's best to have an accurate measurement to be sure of possible problems.
Old 05-23-2007, 02:50 PM
I've heard of using modeling clay on the piston top and going thru a couple rotations to check for clearance. If you mill the head or the deck, for sure you should check clearance. I would do that on all the cylinders if I were putting some money into the engine, or changing the cam.
I would bet that some cam/rocker-follower/lifter/valve combos could lead to interference.
tom
Old 05-23-2007, 06:24 PM
Clay seems to be the best way after over 40 years, that I've been doing it. With zero or positve piston to deck placement and milled heads, you'll need eyebrows in the pistons of varying depth for any cam if the belt should take a holiday.
Old 07-23-2007, 03:26 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
[QUOTE=Pinhead-227]That gives me a lot of information, but nothing specific.
Does anyone know how much can be shaved off a stock 2.3/2.5 cylinder head before hitting water? I want to get to ~10.5:1 compression...[/QUOTE
What have you found out yet? I am looking to shave the head on my 99 Ranger to raise the compression to 11:1. I am running E85 and want to make the engine more efficient on that fuel.
Dan
Chamber size idt-572 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 12-19-2014 12:15 AM
Piston talk..360vs390 Fellenz 1961 - 1966 F-100 & Larger F-Series Trucks 2 11-28-2014 05:19 AM
400 ebrock intake manifold #2171 danimal 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 35 05-15-2010 11:37 AM
400, Dyno2k3 and 4v open chamber heads. ErrorS 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 02-15-2008 06:55 AM
Stock exhaust pipe size? johndo 1999 to 2016 Super Duty 3 08-28-2004 10:34 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
25l, 4cyl, 62, build, clearance, cyl, demitions, engine, engines, ford, gas, measurements, piston, usual, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
