How to replace A/C Compressor Clutch - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-19-2007, 06:42 PM
ebraunusa ebraunusa is offline
ebraunusa is starting off with a positive reputation.
Hello --
I have a 98 Expedition, with a 4.6L. The A/C runs great, but the clutch is making a clanking noise. I looked at the A/C compressor and the clutch and the 5" circular plate is just hanging in there and it is not tight anymore. I can move it around with my hand. There are 3 posts that each one goes thru a 1" circle hole.
When I turn on the a/c, the ac blows nice and cold, it just makes a banging noise.
So, I figure I just need to replace the clutch. Is that correct?
Is that an easy job? It looks like it there is a 8mm bolt in the middle that holds on the pulley. Do I just need to take that off and does it pull out? Do I need any puller?
Thanks
Old 05-20-2007, 03:21 PM
aagitch aagitch is offline
aagitch is starting off with a positive reputation.
Is it making a constant banging noise or just when you engage it? If it's only when you engage it, I would leave it alone. Some compressors on these engines are known to make clank noises on engagement.
Old 05-25-2007, 12:37 PM
Bad clutch -- fixed
Hi all --
It was pretty easy fixing the clutch. The seal on the inner bearing broke and that was making it rattle. To fix it I did the following:
  1. Take off the belt
  2. unscrew the 8 mm bolt
  3. the front the of the pully comes off.
  4. Remove the snap ring holding the pulley
  5. Pulley slides off.
I did the reverse order and put it back together. It took me about 40 minutes to change it out and it was my first time doing something like this.
Good luck
A/C Clutch tcjhkbjt 6.0L Power Stroke Diesel 9 09-20-2016 06:33 PM
A/C compressor clutch noisy-2005 Escape V6 DaveTV Escape & Escape Hybrid 18 07-10-2014 11:23 AM
A/C Compressor Clutch texaskid22 1987 - 1996 F150 & Larger F-Series Trucks 1 02-21-2011 10:36 AM
93 Ranger A/C clutch or compressor bad? 1998Ranger25L153CID Ranger & B-Series 2 02-11-2010 06:41 PM
A/C Compressor Clutch Clearance IronMiner 1997 - 2003 F150 7 02-18-2007 12:54 PM
Tags
2000, 68, ac, air, change, clutch, compessor, compressor, conditioning, expedition, f150, f250, ford, replace, replacin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
