vacuum help - Ford Truck Enthusiasts Forums
vacuum help
Old 05-19-2007, 01:46 PM
bgfzy bgfzy is offline
bgfzy is starting off with a positive reputation.
Question vacuum help
1979 F-250 4x4 400ci standard tranny. i had a shop work on my truck, they left numerous vacuum lines disconnected includeing vacuum advance my truck runs awfull. I cannot find the orignal location for this connection I tried to hook it up to manifold vacuum no it seems to be advanced all the time. I went to autozone.com got a diagram for vacuum hoses and it looks like i am missing a vacuum restrictor. if anyone has any ideas please help
Old 05-19-2007, 01:55 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
First.... Welcome to the site !
The Vacuum advance hose is supposed to run to the Thermal switch on the T-stat before the switched hose runs to the PORTED vacuum port on the front of the carb..or front side of the carb.
There are several hose routings for these trucks and maybe you have the wrong one.
Is there a white sticker on the passenger side valve cover?
post that info if you have it
There are about 16 different routings for a 79 400.
This should be close to the hose routing you require
7-73-R10
Old 05-19-2007, 02:34 PM
thanks i'll give it a try !
Old 04-15-2014, 12:30 AM
dragonrider dragonrider is offline
dragonrider is starting off with a positive reputation.
is there any way i can get a copy of this vacuum diagram i am getting ready to replace the motor in my 78 f250 and need this diagram 7-73-R10 this is the only place i have seen it
Old 04-15-2014, 12:47 AM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Quote:
I sent you an FTE email message.
Old 04-15-2014, 02:46 AM
my email is cmspray@yahoo.com
Old 04-16-2014, 12:33 AM
thanks this will help a great deal
NO Advance Vacuum xr_guys 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 09-19-2011 04:09 PM
Duraspark2/YF carb/vacuum difference 1986F150six Ford Inline Six, 200, 250, 4.9L / 300 7 08-03-2011 02:32 PM
4x4 vacuum switch problem? Crewcab Turbo 1999 - 2003 7.3L Power Stroke Diesel 12 06-08-2011 09:19 PM
What is the purpose of this vacuum line (diagram included) MitchD Ford Inline Six, 200, 250, 4.9L / 300 25 01-06-2011 04:27 PM
Venturi Vacuum and Vacuum Advance Superred2 Ford Inline Six, 200, 250, 4.9L / 300 5 12-15-2010 12:43 PM
Tags
2002, 350, 50, 79, explorer, f150, ford, hose, layout, liter, manifold, r10, routing, truck, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
