collapsed top radiator hose - Ford Truck Enthusiasts Forums
Old 05-18-2007, 03:12 PM
broncoboke broncoboke is offline
broncoboke is starting off with a positive reputation.
Is there air in the system?
when I run the truck for a bit and shut it off, the top hose collapses.
There is water in the radiator.
Water comes out of a capped T that is in the heater hose if I unscrew it, whether engine is running or not.
Any ideas on whats going on here?
Thanks.
Old 05-18-2007, 03:43 PM
MRL123 MRL123 is offline
MRL123 is starting off with a positive reputation.
What is the overall condition of the hose like? Is this a new bargain basement hose that doesn't have the big spring in it? Alternatively, if the hose is as old as the truck that could be the issue right there. The other possibility could be a failing water pump. If this is a new water pump is it rotating in the correct direction?
Perhaps a little mopre information about the overall condition of the heating/cooling system might help a bit.
Post back with what you can.
Cheers!
Mike
Old 05-18-2007, 03:50 PM
NEw water pump 4 months old.
New Hose, New radiator 2 days ago. Temp guage runs between o and r of Normal.
No Spring in Hose. New Thermostat. Water Pump runs in the same direction it always has. All I can think of.
Thanks.
Old 05-18-2007, 03:52 PM
What would indicate a failing water pump? There is no water coming out the weep hole. and its not squealing or making bad bearing sounds. With the radiator cap off the water moves so I guess its working.
Old 05-18-2007, 05:41 PM
netscaner netscaner is offline
netscaner is starting off with a positive reputation.
Is the cap bad ? As the engine cools, it must be able to draw from the resevour.
Is the resevour hose clogged ?
Old 05-18-2007, 06:12 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
get a spring and put it in the hose
this is a common problem and can cause your engine to overheat
the pump causes a suction when the thermostat is closed
this causes the hose to collapse
you need a spring to stop it
Old 05-18-2007, 06:22 PM
Popa Tim Popa Tim is offline
Popa Tim is starting off with a positive reputation.
BINGO!
As the engine cools, the coolant shrinks and the resultant vacuum should cause the radiator cap to sucked open and thusly draw in coolant from the resevoir.
It sounds like a bad cap or a pinched/blocked/plugged resevoir tube.
Old 05-18-2007, 06:53 PM
I'll try the cap and sping
Thanks a bunch
Old 05-19-2007, 12:55 AM
felixr's Avatar
felixr felixr is offline
felixr is starting off with a positive reputation.
lol you dont need a spring. some people swear by it others curse it
dont treat the symptom
treat the cause
your hose is collapsing for a reason. dont just put a band aid on it
i dont remember the reason these hoses collapse. . . i'm trying to remember . . i think it was either the water pump was bad, the t-stat was bad or the system had an air pocket
as i said, i can't remember
i think there was also some talk about a vacuum caused by the pump if i am not mistaken
someone on here knows for sure cause we have talked about it before
do a search, don't just go by this thread cause no one here seems to know the correct answer
no offense guys but there -is- a definite answer to this dilema
Old 05-20-2007, 04:01 PM
Silentst2000 Silentst2000 is offline
Silentst2000 is starting off with a positive reputation.
Sounds like a bad cap
After it cools off and the hose is collapsed, remove the cap and if you get a suction effect like their is a vacuum in there then the problem is the cap. Those springs are meant for the lower radiator hoses because the pump can collapse them from the amount of volume they try to bring into the engine.(assuming traditional coolant flow engines)
Old 05-21-2007, 08:44 PM
rainbowATF rainbowATF is offline
rainbowATF is starting off with a positive reputation.
Had same problem. Changed hoses etc. Truck came with 8lb cap. Replaced it with stock 12-13lb and collapsed hose was no longer an issue.
Old 05-21-2007, 09:58 PM
alabamabuddog alabamabuddog is offline
alabamabuddog is gaining momentum as a positive member of FTE.
Are you sure it is just after the engin is shut off? If its happening while the motor isrunning it couldbe a cracked head on the intake side. Are you getting any steem out the tail pipe?
Old 05-21-2007, 11:34 PM
Bruce R Leech Bruce R Leech is offline
Bruce R Leech is starting off with a positive reputation.
cap cap cap cap
Old 05-21-2007, 11:47 PM
peppersfords's Avatar
peppersfords peppersfords is offline
peppersfords is starting off with a positive reputation.
I had this problem once...I tried everything....hose, water pump even a new radiator. Called my dad and he started laughing. He said he had a tool that would help me figure out what the hell the problem was and he was coming over for dinner.
He went under my hood and took the cap off and put a new one he got on his way over. I started up my truck and turned it back off again and....PRESTO. It was all good. I stil haven't been able to live that one down. Still brings it up and that was 7 years ago.
Look at it this way. It is like a 5 dollar part...try it and see what happens. Couldn''t hurt.
Old 05-22-2007, 07:25 AM
As well as the cap, it might well be the resevoir is clogged, or the tube that runs to it.
You might want to temporarily remove the tube right where it connects just below the cap.
Top radiator hose collapsed ? norm805 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 08-16-2009 09:26 AM
no heat and trickling water not your usual one rrumba 1997-2006 Expedition & Navigator 28 01-27-2009 08:28 PM
Collapsing upper rad hose 94 F150 Andy63 1987 - 1996 F150 & Larger F-Series Trucks 10 12-06-2006 07:53 AM
Upper radiator hose waldreps Ranger & B-Series 7 04-10-2006 05:25 PM
Problem with collapsing radiator hose!! 88fordranger Cooling, Heating, Ventilation & A/C 9 12-12-2005 07:32 PM
Tags
1991, 302, 350, causes, colapsed, collapse, collapsed, collapses, collapsing, ford, hose, hosed, radiator, top, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
