how to start diesel after sitting 2 years - Ford Truck Enthusiasts Forums
Old 05-18-2007, 11:57 AM
mike b lion mike b lion is offline
mike b lion is starting off with a positive reputation.
Exclamation how to start diesel after sitting 2 years
i'm about to fire up a 466 ihc and a 6.9 ford both haven't been started in a couple years.i live in so.utah where its hot and dry 8 month and cold and dry the rest.got any idea's ? thanks bud
Old 05-18-2007, 01:42 PM
USMC Diesel's Avatar
USMC Diesel USMC Diesel is offline
USMC Diesel is starting off with a positive reputation.
I would start by disconnecting all of the lines to the injectors than crank the engine over to purge all the dirt and air out of the fuel lines.
Then reconnect the lines and back off about a quarter turn on each injector to purge out the remaining air. It should fire right up after that
Old 05-18-2007, 03:16 PM
hotroddsl's Avatar
hotroddsl hotroddsl is offline
hotroddsl has a very good reputation on FTE.hotroddsl has a very good reputation on FTE.hotroddsl has a very good reputation on FTE.
dump the oil & refill first.
Old 05-18-2007, 09:48 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Charge the batteries first and have them hooked up to jumper cables when you go to start it. I'd drain the fuel and change the filter. If you can get to the fuel lines, loosen them at the injectors and crank a few seconds until fuel drips out of the lines. That's how we used to get old tractors fired up. Just be ready to lean on the accelerator a little when it catches until you get all the air & bad fuel out of the lines.
Old 05-19-2007, 08:56 PM
Jacksfirstdiesel Jacksfirstdiesel is offline
Jacksfirstdiesel is starting off with a positive reputation.
also get a couple fresh fuel filters and some marvel mystery oil or Lucas oil or diesel clean.-Just something to lube the IP.
you will probably need new o-rings on the return lines after messing around with it-mcmaster carr pn 9464k24. you'll know if it is hard to start the second time. put a fresh filter full of 50/50 clean diesel marvel or lucas. follow USMC diesel should be good after that. BTW it's a 5/8" open end wrench for the injector fittings
Old 05-21-2007, 02:00 PM
thank you guys for all the info,if it doesn't start after doing all that I'd be surprised.thanks all
Old 05-21-2007, 03:05 PM
oh yeah- make sure to swing a dead cat over yer head 3 times
Old 05-21-2007, 04:30 PM
hotroddsl's Avatar
I'd heard six times doubles youre chances!
Old 05-21-2007, 05:36 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Or do like my brother in law whos Ford diesel farm tractor set out for a year and a half. I'm standing there while he puts a battery in and made the comment this is going to be a @@@ to start, he hits the starter I don't believe it made three revolutions and was running. Had it been mine I'd still be cranking.
Old 05-21-2007, 05:49 PM
from your avatar- you don't need to double your chances. I think you've already doubledD yours;-)
Old 05-21-2007, 05:58 PM
powerstroked162's Avatar
powerstroked162 powerstroked162 is offline
powerstroked162 is gaining momentum as a positive member of FTE.powerstroked162 is gaining momentum as a positive member of FTE.
Dang it Hotrod! I cant concentrate on the thread with those big ol' knockers in my face! lol
Cowboy Steve
Old 05-21-2007, 06:01 PM
hotroddsl's Avatar
tathatts whyy is caaned tt-type!!
Old 05-21-2007, 06:03 PM
lol yes sir, something like that.
Cowboy Stevee
Old 05-22-2007, 03:28 AM
darsey715 darsey715 is offline
darsey715 is starting off with a positive reputation.
how'd it go?
Old 05-22-2007, 09:49 AM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
ckeck fluids
have hot batteries
turn key or mash button
Wheels slipping jmikeyj4 1987 - 1996 F150 & Larger F-Series Trucks 16 12-06-2013 09:29 PM
Intermittent wiper switch kjay 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 11-13-2011 04:43 PM
Pirelli tires - Beware guitarpicr 1999 - 2003 7.3L Power Stroke Diesel 7 07-10-2011 09:33 AM
1989 ford eldurado motorhome joerope 1987 - 1996 F150 & Larger F-Series Trucks 44 08-22-2010 02:28 PM
How do i prevent dry starts? bren_tx 1987 - 1996 F150 & Larger F-Series Trucks 12 02-11-2010 08:49 PM
Tags
350, 69, desiel, diesel, engine, ford, month, months, siting, sitting, start, starting, truck, year, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
