Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-17-2007, 08:27 PM
pfogle's Avatar
pfogle pfogle is offline
Garage is empty, add now
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
patfogle DaPocky
E85 in a '91 302?
Hey guys, just wondering what mods would have to be done to run E85 in a '91 Merc grand monkey with a 302?
__________________
1996 F150 Regular cab, SWB, 4.9. 5speed.
- Life is like a roller coaster, Live for the ups.
- Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
- If you have to ask "Will this hurt?" do not proceed!
  #2 (permalink)
Old 05-18-2007, 10:35 AM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Converting to run E85 is relatively easy. Simply change the injectors to approximately 25% larger ones. Dump in the E85 and go.
If you want to get fancy you could recurve your distributor (if so equipped) for better power and mileage. Edit: Your '91 probably has computer controlled timing, so you'd be out of luck there unless you went with an aftermarket ignition and a duraspark distributor or something like that, or found another way to change timing.
It gets a whole lot more complicated if you also want the option of running gasoline.
  #3 (permalink)
Old 05-18-2007, 01:14 PM
FordTrucksKickGM FordTrucksKickGM is offline
FordTrucksKickGM is starting off with a positive reputation.
You could always do some experimenting to see how much E85 your car can handle. Start with a 20%E85 80%Regular mix then work your way up till the car starts running crappy. Then back it down to where the car is comfortable with it. If you have a high compression engine it can handle more E85. Right now Im running a 50/50 mix in my 99 F-150 and 98 Stratus and it works ok but I lose about 20 miles per tank. Currently E85 is only 10% cheaper than regular gas (at least where I buy it from) so Im barely comming ahead with the price differance.
Tags
302, 91, block, build, changing, compression, e85, f150, flex, ford, fual, high, injectors, run, running, small, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
