1995 Eddie Baour Bronco suspention
i have a 95 Eddie Baour bronco with the 5.8 ltr enegine 3.55 gears automatic loaded. i have another bronco thats a 89 Eddie Baour bronco with a 5.0 ltr enegine 3.55 gears automatic loaded. i have a 3500 pound boat that i pull with both broncos and when i put the boat on my 95 bronco it goes down about 4 to 5 inches when i put it on my 89 bronco it dosen even go down a cm. is there something wronge with my 95 bronco? i looked at the suspention on both broncos and there the same exsept my 89 bronco has a spacer between each leaf and my 95 bronco dosen't? is that normal?
thanks chris
thanks chris
All I can say is that the suspensions are deffinately not the same! Ford made tons of changes over the years. Even if they look the same, they are not.
1995 Bronco Eddie Bauer- 351ci- 4" Pro-Comp lift- 32" Dunlops- Front & rear Maniks- K&N FIPK- Dynomax 3" catback- Awia Head and changer.
