F250 stops
F250 stops
I have a 2002 F250 and I was driving yesterday and it just stalled. I let it sit on the side of the road and started it up again after a minute or so. I got back on the road and it did it again; several times until I made it home. Could this be the Cam Position Sensor? Any ideas? I got a grinding sound a couple of times trying to restart. Help would be appreciated. Thanks
Still dead
I did not change it but I pulled it out and cleaned it. I then tried to start it and the starter solenoid started to smoke. So I went to get a new one and installed it and it started and ran for about 5 minutes and I thought I had it. No luck. So I tried to start it again and this time it would not start.Sounded like the alternator was gone. It worked me over pretty good so I thought I'd call it a day. I then went to lock the truck with the power lock and it would not go done. So I put the key in and now the battery/or batteries are dead. Any ideas!! I will pull the batteries out tommorrow and go from there. Katrina didn't stop me; this truck will not. Scratching my head in New Orleans.
Ravery
Ravery
Ravery,
To my knowledge, there is no cleaning procedure for the Cam Position Sensor. When they fail you just have to replace them $16.
If you cranked the truck long enough to cause the starter/solenoid to smoke then you could have damaged the starter or solenoid and run the batteries down.
Replace the CPS, charge the batteries and see if it will start right up. Hopefully you didn't fry the Starter/solenoid.
Good luck
Good luck
Tell them you want part number F7TZ-12K073-B and not what it is. Or check out www.powerstrokeshop.com
If it was not grinding before your truck quit then i would say yes it is the starter, especially since yesterday you said the starter/solenoid was smoking and you ran down the batteries with extended cranking. You could very well have cooked the starter and ruined it. Starters are only designed for very short operation periods, a matter of seconds. Long crank times on a starter produce huge amounts of heat, which can cook the starter and bearings.
