What steering wheels fit a 56 column?
on
It's been a long time since I dabbled with these but if I remember correctly 49-57 will interchange (F1, F2, F3, F-100, F-250, and F-350). However, those wheels are probably all about the same size so your best bet might be to use an adapter and put an aftermarket wheel on it. Check with Grant Products for an adapter and wheel at www.grantproducts.com.
I'm using a 15" wheel on my Ididit column/Toy box and IMHO it's about the right size. Most of the replacement wheels on the market are aimed at the import/early hotrod market and are 13" which to me looks too small. My wheel is a Grant. The wheels used thru 50s were large to give more leverage for the "armstrong" steering. The stock wheel feel like you are driving a bus.
Received 1,353 Likes
on
