Looking For 89 F150 Wiring Diagram! - Ford Truck Enthusiasts Forums
Old 05-17-2007, 12:38 AM
WATTSUP!'s Avatar
WATTSUP! WATTSUP! is offline
WATTSUP! is starting off with a positive reputation.
Does anyone know where I can find a wiring diagram for a 89 f150? Having issues under the dash and need to trace out the wires for the running lights and dimmer light. Pretty much everything that runs off of the number 4 circuitis what I need to trace out. Fuse keeps blowing and its driving me nuts!
Old 05-17-2007, 09:30 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Old 09-17-2013, 12:19 PM
#1spudman #1spudman is offline
#1spudman is starting off with a positive reputation.
i can use wiring for 1989 ford f150 steering column if you have found one #1spudman thanks
Rear running light and plate lamps out - please help sbohl15a 2009 - 2014 F150 16 06-15-2016 12:24 AM
Low Range Light On (2WD Truck) warren561 1987 - 1996 F150 & Larger F-Series Trucks 3 08-20-2015 06:07 PM
complete wiring. diagram? joekacker 1987 - 1996 F150 & Larger F-Series Trucks 1 04-03-2014 06:47 AM
89 f150 engine wiring diagram Melody Reyes 1987 - 1996 F150 & Larger F-Series Trucks 4 07-21-2012 11:37 AM
SPEAKER WIRE DIAGRAM Hunt89 1987 - 1996 F150 & Larger F-Series Trucks 1 01-01-2010 06:22 PM
Tags
1989, 1999, 83, 89, diagram, diagrams, electrical, f150, ford, fuse, harness, schematic, truck, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
