V10 vs. 460 - Page 4 - Ford Truck Enthusiasts Forums
V10 vs. 460
  #46
Old 08-09-2007, 10:15 PM
pops_91710's Avatar
pops_91710 pops_91710 is offline
pops_91710 is starting off with a positive reputation.
Quote:
Originally Posted by stngh8r
V10 cams mmmm?
Yep! http://www.compcams.com/Technical/Ca...2007/pdf/3.pdf
  #47
Old 08-10-2007, 10:05 PM
BIG 78 BIG 78 is offline
BIG 78 is starting off with a positive reputation.
460 RULES v10 DROOLS!!!!!!!!!!!
  #48
Old 08-10-2007, 11:40 PM
gojoe gojoe is offline
gojoe is starting off with a positive reputation.
Having driven many built fe's and 429-460's I wasn't excited about mod motors, especially in trucks, until the first time I took one apart, from a machinery standpoint the mods are beautiful inside.
I was the chassis mechanic at a Ford rv dealer when Ford switched from 460 to V10.
I was lucky enough to drive nearly identical 30' class a's, one 1997 460 and one 1999 V10, so much smoother and more powerfull was the V10, I was falling in love.
Then I start asking owners about their mileage, built 460's averaging 6, V10's stock getting 8. (stock 460's got 4-5, my dads 460 in a '53 f600 gets 5.)
Smoother, more powerfull, better fuel mileage, what's the downside to the V10 over a 460? Oh yeah now instead of beefing my truck up I just drive them and save my wrenches for my racecar.
Still love 460's but like V10's even more.
  #49
Old 08-11-2007, 09:48 AM
Wrenchtraveller Wrenchtraveller is offline
Wrenchtraveller is gaining momentum as a positive member of FTE.Wrenchtraveller is gaining momentum as a positive member of FTE.
Good post Gojoe and the 460's mediocre towing performance and awesome thirst for fuel was what got so many of us into diesels. The incredible towing performance and decent mileage of the V10 has got a few of us back to gas.
  #50
Old 08-11-2007, 12:54 PM
Destroya Destroya is offline
Destroya is starting off with a positive reputation.
just to add, "beefing" a 460 can be a bear in emissions compliant trucks. not much you can do that is legal in a state that has inpections. Even if you did, say you upgraded an intake (who sells an aftermarket 460 efi intake? I've never seen one.) injectors, fuel pump and everything else, to you disappointment, most if not all 460's utilize the EEC Speed density setup which in turn makes your performance parts junk, as it will perform to the computer's programmed limitations and not let the installed performance parts "perform".
  #51
Old 08-12-2007, 02:08 PM
ATXZJ ATXZJ is offline
ATXZJ is starting off with a positive reputation.
Quote:
Not neccessaraly
I agree that the late model EFI 460s were challenged. However, the speed density system did not effect performance with simple bolt-ons (air filters, headers, ETC). I built/raced a speed density 5.0 EFI mustang in the early 90s that ran high 11s naturally aspirated with a stock camshaft and injectors. SD relied on engine vacuum to determine A/F ratio and was not effected until larger camshafts were installed thus reducing engine vacuum. Ford programmed the EEC IV to run extremely lean in the EFI 460. EFI 460s had an issue with cracked exhaust manifolds because of this. An adjustable fuel pressure regulator was a quick fix or you could also step up to a mass air conversion. I worked on quite a few of them in the 90s and the biggest improvement you could make, was installing an adjustable timing chain. The camshaft timing was purposely retarded from the factory and SVO (now FRPP) actually offerd a kit to advance it. They wouldn't even turn the tires beforehand, but after the timing chain, it actually had some guts.
There is no comparison between a 95' 460 and an 01-07' V10. The V10 is more effiecent and has a much wider powerband. A 99 V10 is pretty close stock VS stock, to a 460. Ask me how I know
Marcus
  #52
Old 08-12-2007, 06:00 PM
I also had a 87 speed desnsity mustang 5.0 and added cobra intake, headers, 10.2:1 pistons, frpp camshaft and many other parts and the thing fell on its face until I did a MAF swap. wouldn't idle, miss until 2300 rpm, CEL on all time. MAF was a must when it came to even the first part added.
  #53
Old 08-12-2007, 07:40 PM
Fredvon4's Avatar
Fredvon4 Fredvon4 is offline
Fredvon4 has a good reputation on FTE.Fredvon4 has a good reputation on FTE.
wrench said...
"Good post Gojoe and the 460's mediocre towing performance and awesome thirst for fuel was what got so many of us into diesels. The incredible towing performance and decent mileage of the V10 has got a few of us back to gas"
and it is worth repeating
I owned just about every BB Ford motor ever made and hot rod or modified EVERY one until this wonderful 415 v10 came along...First motor ever that I owned that did NOT need "adjusting with Edlebrock, Crowler, Ed Pink's, Acell, Hedman, Thorley, or Holly help..... if DOHCMaurader wants to wax nostalgic over bloated push rod, cast iron junk so be it,,,,,
I love the fact that the puny V10 will out Hp, out torque, and out fuel efficiency the horrid 460!... and this if from and old fool who would chain up his 460 to any stinking 454 and day any time any where!
  #54
Old 08-13-2007, 01:28 PM
69-highboy 69-highboy is offline
69-highboy is starting off with a positive reputation.
I admit it, I'm a 460 fan, not a fan of the V-10. I shake my head at the balance shaft and other devices used to eliminate harmonics when it wasn't necessary. Chrysler got it right, why Ford didn't I'll never know. The 5 cylinder Audi/VW has been around for decades, so at the very least, one can say the V-10 was over engineered.
I don't buy into the smaller displacement arguments either. If one thinks of the engine as an air pump, which it is, which one do you think pumps more air: 7.5L@3000RPM, or 6.8@4400RPM? The way I see it, Ford's V-10 is a small block with two more cylinders...
  #55
Old 08-13-2007, 01:58 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
If by "right" you mean doing a 90 degree V10 as an "odd-fire" motor, well, yeah, you're correct.
The Ford V10 is an even-fire setup, hence the balancing shaft.
  #56
Old 08-13-2007, 05:44 PM
Fredvon4's Avatar
NOBODY'S power band started as low as and lasted as long as the 415 6.8L Triton V10.... curious huh... I take the balance shaft thank you...and all that smooth pure torque curve with it....
OH yes before I forget... all my 460s made very impressive hp and torque... but that danged things would not motivate my 2 thousand pound lighter trucks down the freeway as fuel efficiently as this puny 415 does my 7800 pound SuperDuty.... in fact if I added a ton of junk in the bed then the 460 would punish me further with a whooping 6 MPG trip instead of it's stellar 9MPG empty average..... I am ecstatic that my 7800 pound 4 door long bed larger scale truck with 5200 pound cargo rating can zoom down the same roads at 12.5 mpg empty and 9.7MPG loaded down.... yep...think I will let all the nostalgic love hate for the 460 slip into memory lane as I pass by with a superior motor trany drive train that does not punish me with the constant tinkering and feeding the mighty 460 did
  #57
Old 08-15-2007, 09:29 PM
pops_91710's Avatar
I don't understand how you can argue with the success of the V10. The engine runs strong and true, balance shafts and all. BTW Chrysler did not get it right, Ford did. The Ford V10 has been proven time and time again to be a better built and better running, more economical engine than the Mope Par. I have not had one single problem with my V10, and I tow a heavy trailer with it. Over-engineered???? Are you kidding? Who cares if it's a small block or a big block, what counts is it gets the job done and done well.
I don't care if anyone wants to live in the past. Old engineering is fun to putz around with and make hotrods. But just because you can't tweak it or need to, don't turn your nose up at it.
  #58
Old 08-15-2007, 10:09 PM
MountainHound's Avatar
MountainHound MountainHound is offline
MountainHound is starting off with a positive reputation.
Talking Who cares?
I love it when Triton V10 detractors call this engine a "small-block" as if that's some sort of insult! Like I'm gonna lose my cool and get mad 'cause someone says the engine in my F250 isn't a "big-block". The big-block is a dinosaur, a figment of a bygone era similar to a dodo bird. Now useless to most, missed by few and an inefficient waste of gas and cast iron to all. Good riddance and R.I.P..
Who gives a ****e if the V10 it's a small block or a big block or maybe even a mid-block?? All I know is it works & it won't break. Plus, hot women think they're cool and the guy driving one has his act together.
Anybody ever have a hot girl come up to you and say "Wanna take me for a ride in your 15 year old oil-burning slow-assed big-block pickup?"! I thought as much.
  #59
Old 08-15-2007, 10:50 PM
DOHCmarauder's Avatar
DOHCmarauder DOHCmarauder is offline
DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.
Quote:
What are you babbling about???
In case it escaped you, I am a V10 supporter. (not so much a POS 4100R supporter).
Even though I think OHC technology is kind of a waste for a 2 valve wedge head.....it lends itself well to multivalve tech.
  #60
Old 08-16-2007, 06:22 AM
Fredvon4's Avatar
Maurader with cams..... I did not say you were not a V10 fan...Many of your posts in this and several other threads, (bemoaning the fact that Ford could/should have evolved the 460 further), sounds to me like you really really liked the BB 460.... I do not think that waxing nostalgic, about what coulda been, is necessarily a bad thing...
I am certainly not "Babbling".... just weighing in with my opinion... V10 415CI...Yea! V8 460 Boo!
Max Tow pushed to the MAX Tom 2009 - 2014 F150 65 01-11-2014 01:14 PM
Ohio Truck Meet Sunday June 23, 2013 Monster-4 Excursion - King of SUVs 11 07-01-2013 08:03 AM
Another Ohio truck meet! Sunday, June 3rd Monster-4 1999 - 2003 7.3L Power Stroke Diesel 8 06-05-2012 07:37 AM
Short "ram" air vs "cold" air intake 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 11-20-2011 09:22 PM
Ohio truck meet, again! Monster-4 Ohio Chapter 4 08-30-2011 09:26 AM
Tags
2001, 2008, 460, big, block, chain, consumes, f250, ford, marks, oil, parts, performance, swap, timing, triton, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
