Too much transmission fluid?
Are you sure it's overfilled. I have yet to be able to get a correct reading off of a drained & re-filled Tranny . I've completely disassembled & re-built 2 , added the exact amount via bottle count & the dipstick shows way over full . This is on 2 tranny reblds. The fluid is so light it covers the dip stick way up . I rely on the bottle count & after many miles accept what the stick says . On a drain I ck the fluid level before the drain, catch all of the fluid if correct level ,measure this amount & replenish with same volume .
A real pain , but the clean fluid messes up the dipstick . I would appreciate anyone elses help on this & their solution to remove the doubt . Sorry about stealing your posting p.s The 3rd time works like a charm !
on
I'm interested to hear what others are reading on their trans dipsticks. I just changed my fluid and filter at home (no powerflush) and after I put in 12 quarts, I checked the level and the dipstick showed way overfull. So I drained out about 2 quarts and now the dipstick reads just above the cross hatch marks. It bothers me that I was only able to put in about 10 quarts when I thought that just draining the trans would remove more.
Frankly, I find it hard just to read the dang dipstick. The fluid is so light that I'm not sure if fluid is being dragged up into the tube "over writes" the actual level. I check my fluid level with the engine in park at normal operating temp.
on
Originally Posted by Big Rig
I agree.. It is very hard to read the dipstick. I too, did the R/R filter and drain the fluid. I put back in about 9.5 qts of tranny fluid..Now it shows just a hairr over the hatch marks when warmed up and put thru the gears..
Spaggs
04-01-2014 12:45 AM
