shifter stuck in park - Ford Truck Enthusiasts Forums
Old 05-15-2007, 07:12 PM
f150v602's Avatar
f150v602 f150v602 is offline
f150v602 is starting off with a positive reputation.
well ive read about it in other threads and it happend to me. My console shifter on my 04 fx4 wont go out of park unless i hit the white release button next to the shifter and im gettin pretty tired of doing that. Has anybody out there found a hard fix for this problem?? Or does anybody know the spacific troubleshooting steps to use when trying to find out whats wrong?? I would apreciate all advice. Thanks
Old 05-15-2007, 07:17 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
I could be wrong but doesn't it mean one of your brake lights are burnt out? Maybe check them (including the high mount 3rd brake light).
-Matt
Old 05-15-2007, 07:54 PM
Cuisinart Cuisinart is offline
Cuisinart is starting off with a positive reputation.
It is definitely tied into the/a brake pedal switch somehow, and it's probalby the same one that actuates your tail lights.
Old 05-15-2007, 08:01 PM
f150v602's Avatar
Is that the most commom problem? The brake light switch? Thats what i have gatherd from other threads. I plan on checking my brake lights but its storming outside right now so i will have to wait. Hey Cuisinart, what kink of lift tire/rim size combo is on your truck?? I love it!! ( sorry to get off topic)
Old 05-15-2007, 10:07 PM
73f350sc's Avatar
73f350sc 73f350sc is offline
73f350sc is gaining momentum as a positive member of FTE.73f350sc is gaining momentum as a positive member of FTE.
Like Matt said....Check your tail lights...if one is burnt out the park shift interlock switch wont let it shift....other than that...is it still under warranty? If so have them take a look.
-Chris
Old 05-16-2007, 02:23 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
I will be a p'off person if I get a call from the wife and she says she is stuck out in town because the truck won't shift out of park...especially if it's something stupid like a brakelight burnt out.
is this true?
Old 05-16-2007, 02:27 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Fist make sure the brake lights work if so the shift interloc is bad. its about a 60.00 part from the dealer.
Old 05-16-2007, 04:55 AM
f150v602's Avatar
[QUOTE=tylus]I will be a p'off person if I get a call from the wife and she says she is stuck out in town because the truck won't shift out of park...especially if it's something stupid like a brakelight burnt out.[QUOTE=tylus] I couldnt agree with you more.
Old 05-16-2007, 04:59 AM
There is a procedure to check the shiftinterlock, i am trying to locate it for you right now.
Old 05-16-2007, 05:13 AM
f150v602's Avatar
Man that would be great, i hope you can find it
Old 05-16-2007, 07:37 AM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Actually the brake lights and shift lock are on separate circuits going thru the brake switch. There are 6 pins to the boo switch and two power circuits. The brake lights are illuminated thru pin 2 on the light green wire and powered thru pin 1 light green and red from fuse 2.02 at the interior fuse box.
The shift lock actuator is activated thru pin 6 pink and light green and powered by pin 5 light blue and pink thru fuse 2.14.
So at pin 1 at the floor shifter module you should get 12 volts with the brakes applied and key on and you should also have 12 volts to pin 2 with key on from fuse 2.15. Pin 6 provides ground.
BTW when I say 12v I am implying battery voltage, what ever that might be for your battery condition and loads with key on.
Old 05-16-2007, 09:40 AM
Quote:
I have a procomp 6" suspension lift on 18x10R18 rims with 35x12.5" tires (nitto terra-grapplers)
and thanks
Old 05-16-2007, 04:21 PM
f150v602's Avatar
well all checks passed. brake lights worked and the brakelight switch works and im getting power to the brake park interlock solinoid. guess that means the solinoid is bad. man i hate that and the part at the dealer cost 220.00. for the mean time i wedged somthing in there to keep the button pressed so i dont have to take off that panel everytime i want to sift out of park. but to make things worse, the spring that is under the shift handle that keeps the shift rod down, well i broke it. dumb *** me . Thanks everybody for your input. It all helped in my quest to solve this stupid problem.
Old 06-08-2007, 11:14 PM
charmedbridge charmedbridge is offline
charmedbridge is starting off with a positive reputation.
Shifter stuck in park.
We had the same problem with our 97 f-150! All it was were a few fuses in the dash! I'm glad I looked here before tearing the darn thing apart!!! It took a total of an hour to figure and fix the problem. Ford Forum Rules!
Old 06-09-2007, 12:00 PM
benningstspeed1.0 benningstspeed1.0 is offline
benningstspeed1.0 is starting off with a positive reputation.
7l3z-7e096-a List $136.62
C6 shifter problem Ronnief150man 1973 - 1979 F-100 & Larger F-Series Trucks 11 12-08-2016 11:19 PM
F250 7.3 help!!! Daniel Henao 1999 to 2016 Super Duty 1 04-11-2016 08:49 PM
Park switch roadapple 6.0L Power Stroke Diesel 4 06-26-2013 07:55 PM
Shifter Column issue? pizza guy 1999 to 2016 Super Duty 2 05-20-2011 12:03 PM
Shifter linkage johnnydmetal Clutch, Transmission, Differential, Axle & Transfer Case 4 07-17-2007 10:02 PM
Tags
2004, 7e096, 7l3z7e096a, drive, excursion, f150, floor, ford, number, park, part, power, shift, shifter, stuck, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
