Corroded HFCM drain plug - Page 2 - Ford Truck Enthusiasts Forums
Old 05-16-2007, 07:45 PM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
Quote:
Originally Posted by glm racers
I'm thinking that the draining procedure releases trapped air?
If you are getting air into the fuel system the truck will not run properly and the injectors will be starved for fuel which is going to cause the injectors to prematurely fail.
You may have a leak in you fuel system somewhere between the HFCM and the fuel tank. I would definitely have it looked at before it cause major problems to the injectors.
Old 05-16-2007, 10:08 PM
garcherd garcherd is offline
garcherd is starting off with a positive reputation.
The Ford Motorcraft fuel additive is good stuff. One bottle treats 125 gal of fuel. Make sure to use the one for 6.0 PSD as they make one for the 7.3 and it's different. If you have never used it before, put a whole bottle in (1 quart) when you fuel up and get on the highway and drive it like you stole it. That additive will keep the EGR from coking up and sticking. Sells for about $6.50 a bottle, that's cheaper than any mechanic.
Fuel filter change - drain question joeinca 6.0L Power Stroke Diesel 10 05-22-2016 08:48 PM
Low Sulfur Diesel VS Ultra Low Sulfur Diesel Carolina Rig 6.0L Power Stroke Diesel 8 10-30-2015 08:42 AM
Do I need to worry about ULSD ? CoachCL 1999 - 2003 7.3L Power Stroke Diesel 13 05-23-2014 12:20 PM
Oil grrr lubriguard? Talyn 1994.5 - 1997 7.3L Power Stroke Diesel 35 02-14-2012 08:40 AM
Preparing for a 3000 mile road trip cornking Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 05-06-2010 02:45 PM
Tags
60, bad, catalogue, corrosion, diesel, drain, f250, fail, ford, hfcm, ih, injectors, location, plug, procedure, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
