HELP, I need a tranny - Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: Toyman
Old 05-15-2007, 02:34 PM
Jimjdb1's Avatar
Jimjdb1 Jimjdb1 is offline
Jimjdb1 is starting off with a positive reputation.
Unhappy HELP, I need a tranny
I just purchased a 1995 Ranger Splash and it needs an auto tranny. It has a 4.0 cid engine and is 2 wheel drive. I can find all kinds of tranny's for 4X4 but none for a 4X2. If anyone can help me out please PM me. The body of this truck is in beautiful shape so its worth putting a few bucks into.
Thanks
Jim
Old 05-15-2007, 03:15 PM
taisa899's Avatar
taisa899 taisa899 is offline
taisa899 is gaining momentum as a positive member of FTE.taisa899 is gaining momentum as a positive member of FTE.
you tried car-part.com?
Jim
Old 05-16-2007, 02:28 AM
Crash687's Avatar
Crash687 Crash687 is offline
Crash687 is gaining momentum as a positive member of FTE.
Try these guys: http://www.middletonautoparts.com/They can usually find what your looking for even if they do not have it.
Old 05-16-2007, 10:47 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Why can't you just switch the output on the new one with the old one....?
Old 06-10-2007, 10:26 PM
racecort_91 racecort_91 is offline
racecort_91 is starting off with a positive reputation.
find an aerostar they should have the same a4ld tranny.
Old 06-10-2007, 10:28 PM
if it has the 3.0 change the bellhousing the front pump goes with the bellhousing make shure it is good.
Old 06-16-2007, 02:40 PM
Jimjdb1's Avatar
Thanks for all the help guys. The truck is a thing of the past. It was going to cost more to repair it that it was worth so I got rid of it.
Thanks again guys.
Jim
LOOKING for an F1TA Transmission 3Jimbo3 1987 - 1996 F150 & Larger F-Series Trucks 4 10-12-2011 09:28 PM
Transmission fluid change hammer65 1999 to 2016 Super Duty 8 06-26-2009 11:55 AM
Calling all tranny gurus Cuda_jim 1994.5 - 1997 7.3L Power Stroke Diesel 0 06-11-2007 09:20 AM
eats starters Jim88554 New Member Introductions 2 03-11-2007 07:47 AM
1994 F-250 460ci - What else do I have? Jim McAllister 1999 to 2016 Super Duty 2 08-13-1999 11:43 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
