keyless entry stopped working
Hello all, on my 99 DRW my keyless entry just stopped working. Either remote doesn't respond. I replaced battery on one of the units just to eliminate the obvious. I checked a few fuses and they are ok. I am planning a more thorough search one evening but any ideas what I should be looking for? Don't know if this is related or not but my left turn signal blinks very fast all of the sudden as well.
-Rick
-Rick
Rick,
Take your key put it in the ignition and turn it to off, then turn it from run to off 8 times ending with the key on, the locks should cycle once. if they do not, then you module is dead. If they do cycle, press one button on a single remote and they should cycle once more and then turn the key back and pull it out.hopfully if should work by then.
twigsV10
1997-2006 Expedition & Navigator
13
09-28-2015 10:33 AM
